46
OnePlus 7 Pro battery/heating feedback thread
  1. Swejuggalo
    KitKat Oct 14, 2019
    Swejuggalo , Oct 14, 2019 :
    If some app or service is misbehaving and draining battery very fast some heat can be normal. Try to look at the battery stats and see if you find something behaving abnormal.
  2. Swejuggalo
    KitKat Oct 14, 2019
    Anything special in the battery stats that drains the battery? If some app or service missbehaves it can take a huge hit on battery life.
  3. Swejuggalo
    KitKat Oct 14, 2019
    More or less depends how far away from a charging opertunity you normally are. If possible you should avoid really deep discharges anyway.
    I think 15% is standard. Personally I avoid discharging below 20%. Most days I really struggle to drain even close to it anyway. My typical usage drains too little per day it seems [e]1f609[/e]
  4. laxmisagar021
    Cupcake Oct 14, 2019
    laxmisagar021 , Oct 14, 2019 :
    yeah, already checked this part before posting the query.
    there were no apps in the background. I will try to track the usage and battery behaviour for another couple of days.
  5. 73ND41
    Ice Cream Sandwich Oct 14, 2019
    73ND41 , via OnePlus 7 Pro , Oct 14, 2019 :
    thanks, I've set scale to 15%. The reason my screenshot says 5% is because I hadn't adjusted it yet before post.
  6. Swejuggalo
    KitKat Oct 14, 2019
    I use BetterBatteryStats myself. Gives some nice extra stats.
    Some examples added.
    laxmisagar021 likes this.
  7. Jing Xiang
    Froyo Oct 14, 2019
    Jing Xiang , via OnePlus 7 Pro , Oct 14, 2019 :
    It states that the screen drains 32%
  8. Daniereu
    Donut Oct 15, 2019
  9. nparameah
    Eclair Oct 15, 2019
  10. KAKAZUYA
    Cupcake Oct 16, 2019
    KAKAZUYA , Oct 16, 2019 :
    Definitely! now I have an average of 3h so I feel it lasts less then before
    akhillad likes this.
  11. arabinow
    Froyo Oct 16, 2019
    KamalJat808 and akhillad like this.
  12. Federico Prencipe
    Froyo Oct 17, 2019
    Federico Prencipe , Oct 17, 2019 :
    After the update to Oxygen 10.0.1 things started to feel a little better but still far from expected. Battery life increased but it is not even close to before the update to Android 10.
    Now it's "variable", I could achieve 7h of screen time but at the same time some days the phone did not last even until dinner, this is not reliable at all.
  13. whiteangelspaperplanes1
    Cupcake Oct 19, 2019
  14. JNiemi
    Gingerbread Oct 20, 2019
    JNiemi , via OnePlus 7 Pro Nebula Blue , Oct 20, 2019 :
    Pretty high consumption, using as a test phone not daily driver. Forced FHD+ @ 60Hz, all background activity prohibited. Wifi 95% (5GHz) and 4G 5% of using network.
    Not good at all, but its only my opinion.
    KamalJat808 likes this.
  15. Federico Prencipe
    Froyo Oct 21, 2019
    Federico Prencipe , Oct 21, 2019 :
    It's not just an opinion, you're right, there is a big problem with Android 10 and that's well known from OP itself. There are thousands of feedback about this and even about worse things.
    KamalJat808, akhillad and JNiemi like this.
  16. Q1571819714906
    Cupcake Oct 23, 2019
  17. StopItRawr
    Honeycomb Oct 23, 2019
    StopItRawr , Oct 23, 2019 :
    Yes, go to bed, it's 2am where you are.
    Seriously though, I long gave up on making my battery last x time and have a charger near me at all times. So long as it doesn't die in a couple of hours use!
    Chrome is a power hungry git too though. Wish I was able to transfer the hundreds of stored passwords to a different browser to test as it's always the highest power draw on my phones.
  18. Q1571819714906
    Q1571819714906 , Oct 23, 2019 :
    It's 2PM!
  19. StopItRawr
    Haha that makes more sense!
    I firgured as it said 2:01 and the battery would last until 11:30am that the thing was going to last another 9 hours, :p
  20. Q1571819714906
    Im talking abt screen on time. 32% battery for 1hr50min? i think my phone is draining too much so i posted this
