55
OnePlus 7 Pro battery/heating feedback thread
  1. Federico Prencipe
    Gingerbread Dec 3, 2019
    Federico Prencipe , Dec 3, 2019 :
    What's the ambient temperature? Where do you live?
    Anyway it's a bit hot
  2. JessePreacher
    Cupcake Dec 3, 2019
    JessePreacher , via OnePlus 7 Pro , Dec 3, 2019 :
    It's 25-26C in my room and 0C outside. I also measured CPU temperatures while CPU stress test. There was no throttling but CPU was up to 83C on the most powerful core and others were about 70C.
  3. Federico Prencipe
    That's too hot, but that's also a very common problem, a lot of people are facing overheating and high battery draining on Android 10. That could be your problem.
    JessePreacher likes this.
  4. JessePreacher
    Cupcake Dec 3, 2019
    May the downgrade to android 9 solve a problem? Or going to android 10 beta instead of stable?
  5. Federico Prencipe
    JessePreacher
    May the downgrade to android 9 solve a problem? Or going to android 10 beta instead of stable?​
    I think the downgrade has more probability to solve the problem than going to beta from stable. Maybe changing to beta will solve but going back to 9 it's pretty sure you'll solve the problem since with 9 nobody had any kind of problem.
    Watch out for data loss if you downgrade, make sure to have a backup of your data.
  6. JessePreacher
    Cupcake Dec 3, 2019
    Okay, I'll try, thanks a lot.
  7. Swejuggalo
    KitKat Dec 3, 2019
    Swejuggalo , Dec 3, 2019 :
    Well... If it does not throttle it passes the heat test.
    I tested with this app. This kind of heat does not normally happen in normal use.
    https://play.google.com/store/apps/details?id=skynet.cputhrottlingtest
    It throttles somewhere over 80°C as intended. The heat distribution and dissipation is always limited in a phone and will reach a limit in a certain amount of time. Reaching max temp and starting to throttle is not nessesarilly a fault. In this case 7 Pro handles it pretty well according to my tests.
    However the other temperatures seems high. Nothing else that causes high idle workload? When you haven't used it for like 30 minutes what temperatures do you have then?
  8. cyclogenesis , via OnePlus Community App , Dec 3, 2019 :
    What's the issue with rooting and the beta? I'm not too familiar with this stuff. Why can't you install the beta with root?
  9. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 3, 2019 :
    You can. But you add potentially external factors that affect the end result on how the device behaves. So I feel that I give more useful input with a stock device with no root and mods. So it's just a personal choise of mine.
  10. JessePreacher
    Cupcake Dec 3, 2019
    JessePreacher , Dec 3, 2019 :
    I tested my 7 Pro with the same test and as I said it was 83C max. The thing is that temperatures are high just when I scroll something very fast for example from bottom of gallery and to the top for about 5 times but in a 5-10 seconds of static screen temperatures fall to 37-38C.
  11. naveenkumar281092
    Cupcake Dec 8, 2019
    naveenkumar281092 , Dec 8, 2019 :
    Worst performance after upgrading..
    Issues:-
    1) I am unable to unlock my OnePlus 7 pro even after entering correct password. When I enter the password it unlocks for flash second and goes back to lock screen.
    2) Battery Draining Very Quick.
    3) Heating Issue.
    4)Low performance.
  12. Federico Prencipe
    Gingerbread Dec 8, 2019
    Federico Prencipe , Dec 8, 2019 :
    The last 3 problems are quite common on Android 10, I don't think you can do much about that; the first one instead is weird, I think you can fix it but I don't know how, I'm sorry.
  13. hitmet
    Cupcake Dec 8, 2019
  14. hitmet
    Cupcake Dec 9, 2019
  15. shravanecor
    Froyo Dec 11, 2019
    shravanecor , Dec 11, 2019 :
    i am facing battery drain issue after 10.0.2, update. some times facing heating issue while charging. please fix these bugs in the next update
  16. KevinErtsman
    Cupcake Dec 11, 2019
    KevinErtsman , Dec 11, 2019 :
    Major battery drain now after 10.0.0.2 and 10.0.0.3 updates, use to be a solid phone, very disappointed now.
  17. Federico Prencipe
    Gingerbread Dec 11, 2019
    Federico Prencipe , Dec 11, 2019 :
    Yes, me too. On Android 9 was an amazing phone, now is just a mediocre one with battery problems, a lot of bugs and other problems.
  18. Neha2006
    Cupcake Dec 16, 2019
    Zvoni likes this.
  19. DFranch
    Donut Dec 17, 2019
    DFranch , Dec 17, 2019 :
    I wound up doing a factory restore then reinstalling the full package (instead of incremental). That finally fixed the battery issues which 10.0.1 introduced on my device.
    B1559977273417 likes this.
  20. saad1957
    Jelly Bean Dec 18, 2019
