58
OnePlus 7 Pro battery/heating feedback thread
  1. I1574339905353
    Donut Jan 11, 2020
    I1574339905353 , Jan 11, 2020 :
    My issues with the battery started after the latest software update. When fully charged, it would state that I have at least 17 hours of life left. Now it gives me 7 hours of life with nothing being used. This is only in wifi
    Update: two days after posting this the battery life returned back to its previous good performance. I'm attaching pictures below of regular usage. With constant usage it will last me a full day and a bit more so this is great. I want to say kudos to the support for teaching out to me regarding the matter. The support for this phone is one of the reasons I'm with this company for close to 4 years.
    skyzoboy likes this.
  2. I1574339905353
    Donut Jan 11, 2020
    Absolute same situation here
    mostic likes this.
  3. Ash_Arora
    Cupcake Jan 11, 2020
    Ash_Arora , via OnePlus 7 Pro , Jan 11, 2020 :
    i am using one plus 7pro and battery of the phone was at 75% by the time I reached to the destination battery drained 43% and reached to 32% where I shut off the data n GPS both in those areas where traffic was heavier.
    This never happened with one plus 5.
  4. Cervantes
    Lollipop Moderator Jan 11, 2020
    Cervantes , Jan 11, 2020 :
    Hi
    Please, use this thread for battery problems
    You can upload screenshot of battery, by google browser
    1. battery
    2. battery uses
    Use the search engine before opening a new thread
    Thread merged
  5. skyzoboy
    Cupcake Jan 12, 2020
    skyzoboy , Jan 12, 2020 :
    it's never enough, for me i connecting all the time at "march of empire" my batterie cannot finish the day... finally like my old phone (nokia 7+)
  6. nathan02
    Cupcake Jan 13, 2020
    nathan02 , Jan 13, 2020 :
    hi guys I need helo. much appreciated. im loving my 7 pro. bought it last Nov. it was superb. only prob is I feel like battery drains fast? is it just me?? here is my concern
    when i sleep overnight battery goes from 83% to 76 or sometime 73% in the morning. and that waa just around say 5 hours from my sle
  7. AnantDags
    Gingerbread Jan 14, 2020
    AnantDags , via OnePlus 7 Pro , Jan 14, 2020 :
    Battery life is so bad in this phone. I'm getting less than 4 hour SOT in a single charge without gaming or any intensive task. I used to get 8 hours SOT earlier with the same apps. And this shitty solution of wiping the phone doesn't work. It has to do with the software.
  8. NikoForzaBrixen
    Donut Jan 14, 2020
  9. skyzoboy
    Cupcake Jan 15, 2020
    skyzoboy , Jan 15, 2020 :
    am agree with you but many people complain about this phone too heavy also...
  10. H1579025668865
    Cupcake Jan 17, 2020
    H1579025668865 , Jan 17, 2020 :
    me too please help !!!!
  11. Shopy
    Cupcake Jan 19, 2020
  12. cirillo30
    Gingerbread Jan 19, 2020
    cirillo30 , Jan 19, 2020 :
    I also notice the same problems. I tried with a reset and after a couple of charging cycles the problem is still present. Indicatively I have lost a good 30% of battery since I switched to Android 10
  13. jasemanONE
    Honeycomb Jan 19, 2020
    jasemanONE , Jan 19, 2020 :
    Has anyone here in this thread done the painful factory reset? Sometimes, when it comes to Android, you have to just bite-the-bullet and do what you don't want to do to see if it helps. YMMV
  14. cirillo30
    yes of course :)
  15. liam_davenport
    Gingerbread Jan 23, 2020
    liam_davenport , Jan 23, 2020 :
    Anyone noticed their battery as degraded severely on the 7 Pro? Like I've had the phone less than a year and it's already reporting the capacity to be around 2000mAh... This is unheard of degradation on a smartphone battery. To check yourself run this command via adb: adb shell dummpsys batterystats > batterystats.txt and search for capacity in the txt mine is reporting:
    Estimated battery capacity: 2195 mAh
    Min learned battery capacity: 2195 mAh
    Max learned battery capacity: 2195 mAh
    Is the OS reporting the capacity wrong or is their an issue with early batch devices? I mean it's a 4000mAh cell so to half it in less than a year it almost sounds impossible... I've also noticed since Android 10 update that the standby and SOT as fallen off a lot I went from 2-3 days usage to one day at best sometimes struggling to hit even 5hrs SOT... If anyone has any insight would be great to hear from you.
  16. cirillo30
    Gingerbread Jan 24, 2020
    liam_davenport likes this.
  17. P1579875050340
    Cupcake Jan 24, 2020
    P1579875050340 , Jan 24, 2020 :
    Yeah like anyone in there right mind will start writing everyting is good with their phone, paid NPC
  18. kunalyadav2234
    Cupcake Jan 25, 2020
    kunalyadav2234 , Jan 25, 2020 :
    battery backup is very very poor in oneplus 7 pro mi phones or miui Rom have far better & more optimize than oxygen os even caf base rom have better in terms of battery life. please oxygen os dev improve this fast and Add more features rich oxygen os and clean os .
