73
OnePlus 7 Pro battery/heating feedback thread
  1. Ichig0
    Cupcake Apr 18, 2020
  2. Thomas Daubizit
    Eclair Apr 18, 2020
    Thomas Daubizit , via OnePlus 7 Pro , Apr 18, 2020 :
    Hello all,
    Still the same Issue for me. Impossible to end a day with only one charge. In every tests, testers said one day and a half, sometimes two days with one charge !
    I think that I don't have the same phone... I tried Wipe Cache, Complete Wipe data... nothing works !
    Oneplus is investigating with my log files. But still no news... We will see !
    "Android system" is draining exactly as the screen. Sometimes more... It is not good. 90Hz activated of course.
    Sampad Roy likes this.
  3. manojpa
    manojpa , Apr 18, 2020 :
    My phone is heating too much after latest update.pls give me solution if any .I am on 10.3.2 indian version
  4. A1579461034355
    Cupcake Apr 19, 2020
    A1579461034355 , via OnePlus 7 Pro , Apr 19, 2020 :
    RESPECTED SIR ,
    MY PHONE HEATS LIKE I CAN MAKE SOME DISHES ON IT RATHER THAN USING MY KITCHEN. I CANT EVEN PICK IT UP BY MY HANDS , I HAVE TO USE SOME CLOTHS . THIS ALL PROBLEMS HAPPENED BY USING PUBG ( GAMING ) FOR ONLY 30 MINUTES ONLY . MY PHONE IS ONLY 3-4 MONTHS OLD. I NEED REPLACEMENT OF MY PHONE BUT I KNOW U BIG RICH COMPANY LIKE ONEPLUS WILL NEVER REPLY TO US OR UNDERSTAND OUR PROBLEMS . BUT AT LEAST I TRIED .
  5. vishal_anand45
    vishal_anand45 , Apr 19, 2020 :
    Hi everyone, hope you all are well.
    Anyone experiencing heating issue while charging oneplus 7 pro?
    please help me with this.
    Thanks
  6. Sampad Roy
    Froyo Apr 19, 2020
    Sampad Roy , Apr 19, 2020 :
    Many people are.
    Not only while charging..
    after the latest update the phone tends to heat up even for normal usage and a bad battery drain can also be observed suddenly.
    Sometimes even No Network coverage.
  7. Nagashekar_ananda
    Cupcake Apr 20, 2020
    Nagashekar_ananda , Apr 20, 2020 :
    OnePlus 7 pro battery drain issues after update - A10
    This had me going through a lot threads but didn't find any solution for this ! Average battery backup is reduced to 4.5hours from the previous 6.5-7 hours of SoT
    Tried switching off the printing device option .
    Tried resetting the WiFi, Bluetooth and network settings.
    Tried wiping out the cache from the device.
    Nothing is working! Please help me out !
  8. Ichig0
    Cupcake Apr 21, 2020
    Ichig0 , via OnePlus 7 Pro T-Mobile , Apr 21, 2020 :
    we are the same my friend, waiting for any update that solves this problem of the battery ...
  9. G_Kirk_Fontaine_MBlG , via OnePlus 7 Pro T-Mobile , Apr 21, 2020 :
    Ichig0
    we are the same my friend, waiting for any update that solves this problem of the battery ...​
    From what I understand is that the covid 19 virus is having a impact on updates since a lot ofthose people are working from home
    plz be patient and know that they are working from resources that they have or may not have
    I am using the same Android 10 version with media player issues probably from bugs that need to be addressed in future updates frustrated as I am but one plus just came out with the 8 series so they are going to make profit and sales going forward especially now
    phones are like cars that as soon as u take them outside the POS then they depreciate
    it is capitalism
    Nagashekar_ananda likes this.
  10. M.A.A
    Cupcake Apr 22, 2020
  11. shaffii
    Cupcake Apr 23, 2020
    shaffii , via OnePlus 7 Pro , Apr 23, 2020 :
    hi my OP 7 pro getting abnormal heat at the time of charging and also auto switch off while charging
    for normal use also it's getting heat, browsing, Facebook, whatsapp and normal calling
    any suggestions and tips pls
  12. Q1509340366887
    Q1509340366887 , Apr 23, 2020 :
    Hi,
    Recently there was a new update released after which the phone has started heating like never before . This issue has been noticed everytime when the device is put to charge (Warp original) . Kindly have a look into this and provide me with a solution.
    Thank you
    Shonith Bhat
  13. @sivan
    Eclair Apr 24, 2020
    @sivan , via OnePlus 7 Pro , Apr 24, 2020 :
    when i am changing my oneplus 7pro its too hot i cant hold on my palms thr same thing happens while doing Oneplus 8 pro AR unboxing on instagram in that time my phone is too hot. please OnePlus techie guy's immediately solve ittt..
  14. Cervantes
    Lollipop Moderator Apr 24, 2020
    Cervantes , Apr 24, 2020 :
    Hi
    Please read the first post
    for another user to suggest: upload a screenshot of:
    battery and other
    battery uses
    You can install cpu-z, which gives thermal report
    Use the search engine before opening a new thread
    Thread merged
  15. @sivan
    Eclair Apr 24, 2020
  16. @sivan
    Eclair Apr 24, 2020
    actually this issue was i am getting on latest update 10.3.2 how can you merge to previous thread its not fair. @cervartes
  17. Cervantes
    You have created three threads with the same content
    Please read the forum rules
  18. Tumio
    Gingerbread Apr 25, 2020
    Tumio , via OnePlus 7 Pro , Apr 25, 2020 :
    I have already left feedback to oneplus with log of the file regarding the disproportionate use of whatsapp in the background.
    By comparing it, for example, with Telegram, the latter is almost non-existent.
    This inevitably leads to excessive battery consumption.
    I would like you to share your problem if present and to report it to Oneplus.
    Thx.
  19. Tumio
    What is the wifi setting in the developer options to activate?
  20. Deactivated User
    Apr 25, 2020
    Tumio likes this.
