72
OnePlus 7 Pro battery/heating feedback thread
  1. Ichig0
    Cupcake Apr 27, 2020
  2. S1571160218053
    S1571160218053 , Apr 27, 2020 :
    I have just updated with Oxygen OS 10.3.2 and since then my batter seems be draining very very fast. My usage is moderate. Before the update, my battery would last longer despite watching videos and movies. Are others also facing the same issue after downloading the new oxygen OS update?
    momar1988 and Sampad Roy like this.
  3. Ichig0
    Ichig0 , via OnePlus 7 Pro T-Mobile , Apr 27, 2020 :
    Me friend, I have the same problem after updating, waiting for an update to correct this bug, regards
  4. frankkn85
    Eclair Apr 30, 2020
    frankkn85 , Apr 30, 2020 :
    Since a month now the phone is like a charcoal always warm & after using to check messages & stuff it's a furnace the screen is always warm if I hold it in hand & that is making the battery drain faster. I have done a full reset to check if any app was causing problem but its still same. I don't get it where it has liquid cooling thing inside how its still shooting up so much temperature. Is the coolant dried up?
    Battery backup has gone awful If I full charge it in morning by late evening I've to charge it again also the usage is moderate not heavy don't even play games over it. Earlier it was better even with higher refresh rate but due to this I reduced it to 60Hz still same no improvement. I even tried turning of location doesn't improve much. There is something needed to be fixed after screen ambient part maybe its keeping powering pixels without any usage in background hence device remains warm without usage.
  5. Spart0n654
    Cupcake Apr 30, 2020
    Spart0n654 , via OnePlus 7 Pro , Apr 30, 2020 :
    I had this problem before I rooted it and used a different kernel and changed the kernel settings. now it barely warms up ever and still beats my stock benchmarks.
  6. Samu2504
    Froyo May 1, 2020
  7. Devendra.ingale
    Cupcake May 1, 2020
    N1577167621927 likes this.
  8. rayanbatarfi
    Cupcake May 4, 2020
    rayanbatarfi , via OnePlus 7 Pro , May 4, 2020 :
    The best Solution HERE
    To rollback to 9 as android 10 have many bug [e]1f41b[/e] 🤣[e]1f601[/e]
    I returned to 9.5.11 no heat and no battery 🔋 eating [e]1f374[/e] [e]1f60c[/e]
    Goodluck to everyone 😎
  9. JoJoNicole76
    Cupcake May 4, 2020
    JoJoNicole76 , May 4, 2020 :
    I've had my 7 Pro for about a year, the last update keeps killing my battery. I used to go more than a day with no problems. Is anyone else having this problem? I've looked into my apps and nothing is using an extraordinary amount of battery. I frequently close all apps, and have everything set to optimize.
  10. Revanth21
    Cupcake May 5, 2020
    Revanth21 , May 5, 2020 :
    I don't know about other phones gaming regarding battery, but on my device i get around 4:30 to 5:00hrs completely from 100 to 5%.Does the time is ok or less ?.
    @sivan likes this.
  11. Charliee@143
    Cupcake May 5, 2020
    Charliee@143 , via OnePlus 7 Pro , May 5, 2020 :
    Bro can I exchange/replace OnePlus7 pro battery 4000mah with one plus8 battery 4300mah. .
    Both phones are same size , battery size also same but capacity was more mah in OnePlus 8 . Is there any chance to put that battery to my OnePlus 7 pro
  12. V1546905985554
    Cupcake May 7, 2020
    V1546905985554 , via OnePlus 7 Pro , May 7, 2020 :
    phone heated very badly every time i use the phone normally.
    while using video chatting the pop camera also heat up. what the hell is 10 layer cooling system doing??
  13. C1588894208469
    Cupcake May 8, 2020
  14. A1515415533392
    Cupcake May 9, 2020
    A1515415533392 , via OnePlus 7 Pro , May 9, 2020 :
    I don't know about any other models but my phone's temperature at idle state is around 40°c and while gaming (pubg mostly) it reaches around 75°c. I don't charge my device while playing neither play it in HDR settings, still it becomes so hot that it's difficult to play another round. The hike in temperature is noticed around playing for 20-25 min.
    Battery temperature while gaming/idle - 40-50°c
    CPU temperature gaming - 60-75°c and idle - 40-45°c
    (I checked the temperature through Antutu)
  15. Revanth21
    Cupcake May 9, 2020
    Revanth21 , May 9, 2020 :
    How much time are u getting to charge your phone???
  16. N1577167621927
    Cupcake May 10, 2020
    N1577167621927 , via OnePlus 7 Pro , May 10, 2020 :
    Exactly the same issue I'm facing.
    Also while charging it's obvious the device heats up but now about a month or so it gets very hot the entire device including camera exterior no kidding.
    So post charging I switch off phone let it cool completely n then use it.
    Simple apps like Quora is really heating up the entire phone.
    It's not consistent either it's gets hot randomly n battery takes a hit due to that.
    If you use wifi 5ghz freq. phone starts to really heat up, if you charge during these times it's gonna get super hot like you feel really uncomfortable holding the device.
    While playing heavy games Call of duty it works fine at times, or it gets hot sometimes.
    Unable to figure out where exactly the problem lies.
    Have been using one plus phones starting from OP6, really surprised with OP7Pro having this issue.
    Let's hope for a fix in near future.
  17. N1577167621927
  18. R1589081988850
    Donut May 13, 2020
    R1589081988850 , May 13, 2020 :
    Hello 7 Pros
    I am extremely happy with my 7 Pro !
    After my pixel 2xL received a software update patch in April, the front camera working.... google half heatedly address the problem but never fixed it.
    I looked at the 7 McLaren edition pro[e]2764[/e]️ I decided to go with the 8 pro[e]2764[/e]️ but to my surprised TMobile does not carry the 8 pro. bummer.
    The 7 pro [e]2764[/e]️ is my formula One edition.
    I have 45 gb to transfer from my old phone and I used the One plus switch and it will not transfer the data after 4 hours..... the 7pro stayed cool as a swimming pool while the pixel got hot as hell....
    No battery heating during charging or data transfer.
