73
OnePlus 7 Pro battery/heating feedback thread
  1. Artemus.
    Nougat May 26, 2020
    Artemus. , May 26, 2020 :
    Unless you got the update a month before it released, I highly doubt you got it in February of 2020.
  2. L1576260318089
    Cupcake May 26, 2020
  3. Artemus.
    Nougat May 26, 2020
    Not trying to debate with you either but your idea of "delayed updates" is a bit delusional. The last update was March 31, 2020 (which we'll probably get a new update come early June) and hasn't reached the 2 month threshold yet.
  4. W1582283910143
    Cupcake May 27, 2020
  5. Nonochiken47
    Froyo May 27, 2020
    Nonochiken47 , via OnePlus 7 Pro , May 27, 2020 :
    SandeepGowda22
    Hello,
    im oneplus 7pro user, there is lot a heating issue when i charge & when playing games. Especially PUBG, i changed all the graphics to low in game settings, however without back case i cannot hold the mobile. is this a battery problem do i need to do anything with it?​
    First, don't play when you charge your phone and second clear the cache into the recovery. This will help you
  6. E1561908060236
    Cupcake May 28, 2020
    E1561908060236 , May 28, 2020 :
    Hi I am using 7pro and I am realising from some days that my phone is heating very badly.
    what is the solution of this?
  7. Liehjan
    Lollipop May 28, 2020
    Liehjan , May 28, 2020 :
    Heating doing what?
    Artemus. likes this.
  8. Funk Wizard
    Lollipop Moderator May 28, 2020
    Funk Wizard , May 28, 2020 :
    Merged with the existing thread
  9. sivlingvimal
    Cupcake May 29, 2020
  10. Vamsi Saladi
    Gingerbread May 31, 2020
    Vamsi Saladi , May 31, 2020 :
    The phone is recently getting too hot while charging. I think OP implemented their fast charging technology into adaptor unlike other phones to reduce phone heating and take load off the phone. and weirdly I was using op 6T with Dash Charging and they said 7 PRO has Warp charge which is faster. But from Day 1 i felt 7 Pro took longer to charge from 0 to 100 than 6t.
    I know 7 Pro has larger battery (300 mah more) but also claimed faster charging with Warp charge. there should not be that much noticeable difference.
    and weired when i connected my 6t dash charger adaptor to charge 7 pro device, my 7 Pro is still warp charing(warp charging displayed on screen). So is this some kind of cheating OP claiming new names and publishing ?.
    I am still satisfied with my 6T , but facing many bugs and performance issues in 7 Pro.
  11. Midhunsebastian , via OnePlus Community App , May 31, 2020 :
    hi.
    my one plus 7 pro was ok until yesterday since 3 months usage. but from yesterday the phone started heating too much while charging and didn't charge fully in 7 8 hrs. still my phone is hot even if I use it for sometime.
    I have been using daily for 10 12 hrs continuous during these months but hasn't noticed such a thing..
    it all started yesterday..
    what could be the reason..
    is there anything I could do now.
    it's very hot that I couldn't hold for long time in my hand without cover.
    when I used a app, it's showing 40°C
  12. Artemus.
    Nougat May 31, 2020
    Artemus. , May 31, 2020 :
    How to calibrate: drain the phone to 10-15%, put it on and leave it on the charger for a few hours (100% is when optimization happens) then take it off the charger, use it again till it reaches 10-15% then do it all over again.
  13. ankurgpa
    Eclair May 31, 2020
  14. Midhunsebastian
    Eclair Jun 1, 2020
    Midhunsebastian , Jun 1, 2020 :
    this is phones today's battery usage.
    in 5 hrs, battery dropped down to 58% from 100 % with 9 min screen usage.
    can anyone explain why this happens
  15. Artemus.
    Nougat Jun 1, 2020
    Artemus. , Jun 1, 2020 :
    I might be able to take a swing at this: you're roaming.
  16. Artemus.
    Nougat Jun 1, 2020
    Yes, exactly. Roaming drains more battery as it's struggling to find a stable connection through a partner carrier.
  17. Midhunsebastian , via OnePlus 7 Pro , Jun 1, 2020 :
    I could understand that but after full charging I didn't touch my phone and it's drained to 58%. thats too much don't you think.
    anyway I could check it.
    also this issue started from day before yesterday only. phone heated up one day while charging and this issue with the battery started
  18. Artemus.
    Nougat Jun 1, 2020
    Might I suggest calibrating the battery then. Drain it to 10-15% via normal means, plug it in and leave it there for a few hours after it reaches 100%. Take it off the charger and do it again a few times.
    Midhunsebastian likes this.
