78
OnePlus 7 Pro battery/heating feedback thread
  1. KirubakaranRohit
    Cupcake Jun 12, 2020
    KirubakaranRohit , Jun 12, 2020 :
    thanks for you kind help could u suggest any apps for slow motion control in videos..??
  2. Artemus.
    Nougat Jun 12, 2020
  3. Nonochiken47
    Froyo Jun 13, 2020
    Nonochiken47 , via OnePlus 7 Pro , Jun 13, 2020 :
    Hello. I don't know if others have this problem. I did the Open Beta 15 yesterday (incremental from Open Beta 14). After, I cleared the cache in the recovery. Today i plugged my phone from 10 to 100 to do 1 optimization cycle. I then unplugged it and in 30 min without doing anything, neither gps, nor 4G, nor Wifi my phone went down to 97. Someone would have an explanation for this problem because usually I lose only 3 or 4 percent in one night.
  4. Artemus.
    Nougat Jun 13, 2020
    Artemus. , Jun 13, 2020 :
  5. Prem1712
    Cupcake Jun 22, 2020
    Prem1712 , Jun 22, 2020 :
    I recently purchased a OnePlus 7Pro and have been getting 4 hours of screen on time on an moderate use which, to my knowledge, is about 2 hours short of the average.
    Resolution: Auto
    Screen refresh: 90Hz
    Brightness: 45%-55%
    I have tried clearing phone cache once but it didn't help. Have attached a couple of screen shots below.
    Please let me know if you know how to fix this. Thanks in advance.
  6. Artemus.
    Nougat Jun 22, 2020
    Artemus. , Jun 22, 2020 :
    Simple: change resolution to 1080p and try playing less CoDM if battery life is that important.
  7. Prem1712
    Cupcake Jun 23, 2020
    Prem1712 , Jun 23, 2020 :
    Nah man, the average is around 6 hours with resolution on auto switch.
    Also, I tried not playing COD but that didn't change much. Thanks for your reply thou
  8. Artemus.
    Nougat Jun 23, 2020
    Artemus. , Jun 23, 2020 :
    What have you tried other than that?
  9. Prem1712
    Clearing cache, as I mentioned. Didn't work.
    Changing charging patterns. Didn't really work.
    If I may ask, how much SOT so you get on your device if it's a Pro?
  10. Artemus.
    Nougat Jun 23, 2020
    My SOT? Probably like... 2 hours max. Then again, I don't really use my phone all that much because I have a PC to use but I can tell you I can go roughly 3 days without having to charge my phone.
    Pro-tip: DO NOT obsess over SOT because it's an arbitrary number that can change from charge to charge based on very specific changes in your usage habits. Use it till it reaches ~15% at the lowest then charge it back up.
    Second pro-tip: clearing the cache via recovery does ABSOLUTELY NOTHING as there's no /cache partition in A/B devices.
  11. Prem1712
    I mean Screen On Time when I say SOT. Are you sure you're getting 2 hours max of Screen On Time? I believe there is a misunderstanding.
  12. Artemus.
    Nougat Jun 23, 2020
    I'm well-aware of what "SOT" means and yes, I'm sure I'm getting ~2 hours. Like I said, I rarely use my phone so the SOT isn't gonna be sky-high like some people who're glued to their phones since the screen isn't actually ON.
  13. Prem1712
    Alright, I get it. Your standby time is way more. Gotcha.
    I'll hold on and see if it changes.
    Thanks, man. I appreciate your time.
    Artemus. likes this.
  14. DianaM
    Cupcake Jun 24, 2020
    DianaM , Jun 24, 2020 :
    I don't know why close a theme for OP7 (without Pro). Is it the same solution for both devices? OP7 and OP7 Pro?
  15. Mr Predator
  16. Artemus.
    Nougat Jun 24, 2020
  17. Mr Predator
    Mr Predator , Jun 24, 2020 :
    And after latest update battery draining is fast so how to stop it.
  18. Artemus.
    Nougat Jun 24, 2020
    Artemus. , Jun 24, 2020 :
    Can't tell you without a screenshot.
  19. Shahid Hakkim
    Gingerbread Jun 25, 2020
    Shahid Hakkim , via OnePlus 7 Pro , Jun 25, 2020 :
    Artemus.
    Can't tell you without a screenshot.​
    is it better to Turn Off Adaptive Battery nd Off Advanced Optmzt or rather turn them On for better Screen On Time values? I am using a 7 Pro at 9.5.11[e]1f609[/e]
  20. Artemus.
    Nougat Jun 25, 2020
    Artemus. , Jun 25, 2020 :
    Uh... I dunno?
