76
OnePlus 7 Pro battery/heating feedback thread
  1. Artemus.
    Nougat Jul 10, 2020
    Artemus. , Jul 10, 2020 :
    Nowhere in this giant heap of pictures of system apps did you even bother to upload a picture of the actual battery stats that will more than likely NOT show any of these items (which use negligible battery life) and taking a frankly-xenophobic approach to it.
    The CIA isn't spying on you nor is China with these apps.
    buntycubal likes this.
  2. R.Peter
    Honeycomb Jul 10, 2020
    R.Peter , via OnePlus 7 Pro Mirror Gray , Jul 10, 2020 :
    No, that doesn't require rooting, as you do it out of the current system. Technically you delete the current OS (OOS) and install another one. Like you delete Windows and install Linux.
    Rooting is totally another thing. And no. If you don't want those "bloatwares", there's either the way to delete them or flash a bloat-free system.
    Paranoid Android is also a very good alternative.
    Artemus. and Shahid Hakkim like this.
  3. Shahid Hakkim
    Gingerbread Jul 10, 2020
    Shahid Hakkim , via OnePlus 7 Pro , Jul 10, 2020 :
    Bro i neede to Unlock the Bootloader for installing another OS right? I am a bit skeptical about the Warranty! Also Backup is a pain in the A**[e]1f602[/e]
  4. Shahid Hakkim
    Artemus.
    The CIA isn't spying on you nor is China with these apps.​
    Duh! Have i told u that the CIA oru AAA is spying me?! I am checkin for a Fix broda[e]1f602[/e]. If u dont know,lemme make it clear. This usage is not shown in Batter Usage Graphs since OP System Hides it anonymously.Please understand nd talk[e]1f609[/e]
  5. R.Peter
    R.Peter , Jul 10, 2020 :
    Yes, you have to. So, either you do that and flash a custom ROM, or you need to live with the "bloatware" you mentioned.
    There are tools to freeze even system apps (on Oxygen OS), but most of them cannot be deleted. Once I did it and after a reboot the system stuck in bootloop :D
    Shahid Hakkim likes this.
  6. Shahid Hakkim
    thanks for mentioning that! Thanks[e]1f60d[/e][e]2764[/e]️
  7. T1569850819566
    Cupcake Jul 12, 2020
  8. Artemus.
    Nougat Jul 12, 2020
    Artemus. , Jul 12, 2020 :
    Is that a good or bad thing? Context is everything.
  9. G_Memo_Abade
  10. G_Memo_Abade
  11. G_Memo_Abade
  12. Artemus.
    Nougat Jul 12, 2020
    Bad multipost.
    Bad multipost.
    Bad multipost.
    buntycubal and G_Memo_Abade like this.
  13. T1569850819566
  14. Artemus.
    Nougat Jul 12, 2020
    Screenshots help, you know. Or else your complaint is moot. Best if drained to 10% to know what's causing it.
  15. Cervantes
    Lollipop Moderator Jul 12, 2020
    Cervantes , Jul 12, 2020 :
    Hi
    Please, use this thread, the battery thread is for questions and comments about the battery
    explain in more detail the problem
    use the search engine before opening a new thread
    Merge threads
  16. Rishusharmaji
    Eclair Jul 14, 2020
  17. Artemus.
    Nougat Jul 14, 2020
  18. Liehjan
    Lollipop Jul 14, 2020
    Artemus. likes this.
  19. Kryxus
    Eclair Jul 14, 2020
    Kryxus , via OnePlus 7 Pro , Jul 14, 2020 :
    What good answers you give, you are customer service because you appear in all publications, if you get tired of the questions, even if they are basic, that is not how you worked.
  20. JEECHAN likes this.
