77
OnePlus 7 Pro battery/heating feedback thread
  1. sunilmufc
    Cupcake Jul 18, 2020
    sunilmufc , Jul 18, 2020 :
    does anyone know what I can do to fix this? battery is losing 30-40% overnight. I've tried killing all apps, put battery saver on too, even airplane mode and it's still happening
  2. Praty_28
    KitKat Jul 18, 2020
    Praty_28 , Jul 18, 2020 :
    Keep your device overnight for charging, do this for a day or two and all of your apps will get optimized. This will make them use much less cpu and they will load faster too.
    When you keep your device on charge overnight and not move it for a long time, it triggers dex2oat optimization. This will create files in the dalvik/art partition which will be used when apps are launched and in turn use less resources. It will take up some space tho, somewhere around 500mb to 1gb.
    Try this method and check if there is still overnight drain after this.
    TheJuli, Artemus. and sunilmufc like this.
  3. L1562312032227
    Cupcake Jul 20, 2020
  4. Cervantes
    Lollipop Moderator Jul 20, 2020
    Cervantes , Jul 20, 2020 :
    Hi
    Please, check and use this thread for battery questions and comments, read the first post:
    Use the search engine before opening a new thread
    Thread merged
  5. BalaDinesh
    Cupcake Jul 25, 2020
  6. Artemus.
    Nougat Jul 26, 2020
    Artemus. , Jul 26, 2020 :
    No update will fix this.
  7. hyzteric
    Cupcake Jul 26, 2020
    hyzteric , Jul 26, 2020 :
    My phone worked very well (like I loved it) until a few weeks ago it started having issues with chrome (it would freeze and I have to force close it) now the issues are all over the place. Overheating, battery drain, spotify will close after a few if it is not the active app, endomondo will "close unexpectedly" every time, waze will cause the phone to overtheat until I have the system message to close to cool down, even using the camera is a nightmare, the app freeze for 2-3 sec then ok for 1 sec, then freeze again, I have to take the picture on the right moment ... I don't understand why everything is a mess all of a sudden :(
  8. mdShahidshams
    Cupcake Jul 29, 2020
    mdShahidshams , Jul 29, 2020 :
    Gmail is draining battery.
    tried clearing cache and storage and switching off.
    still doesn't work
    any suggestions?
  9. Artemus.
    Nougat Jul 29, 2020
    Artemus. , Jul 29, 2020 :
    Turn off auto-sync for all Google items under your account.
  10. sunilmufc
    Cupcake Aug 2, 2020
  11. spot01
    Ice Cream Sandwich Aug 2, 2020
    Artemus. likes this.
  12. sunilmufc
    Cupcake Aug 3, 2020
    sunilmufc , Aug 3, 2020 :
    Nothing shows up as taking 30%. it's just normal stats without the 30% drop. this is with the phone WiFi and mobile data turned off too
  13. GopalB.
    Nougat Aug 3, 2020
    GopalB. , Aug 3, 2020 :
    I can see that you charged 13 hrs ago...
    Do a full charge before you sleep...
    And then in the morning you'll be able to see what app or service used the battery...
  14. sunilmufc
    Cupcake Aug 3, 2020
  15. sunilmufc
    Cupcake Aug 4, 2020
    sunilmufc , Aug 4, 2020 :
    fully charged the phone and went to sleep at 100%. it's on 73% 7 hours later with WiFi and mobile data off
  16. sunilmufc
    Cupcake Aug 4, 2020
  17. sunilmufc
    Cupcake Aug 4, 2020
    any ideas?
  18. Artemus. likes this.
  19. sunilmufc
    Cupcake Aug 4, 2020
    that is full device usage
  20. Artemus. and sunilmufc like this.
