89
OnePlus 7 Pro battery/heating feedback thread
  1. sinisa754
    Cupcake Aug 12, 2020
  2. Tenmujin , via OnePlus 7 Pro Nebula Blue , Aug 13, 2020 :
    After more then a year (got the phone since the start) the battery is starting to show issues
    It drops suddenly from 15 to 1 percent (see the screenshot)
    I never overload the battery nor did i let it go to far down
    Is there anything, that helps or is the battery damaged?
    Thanks
    VipulN likes this.
  3. 橙子木
    Cupcake Aug 14, 2020
    橙子木 , via OnePlus 7 Pro , Aug 14, 2020 :
    oh.....(;゚Д゚)
  4. JE2112
    Donut Aug 17, 2020
    JE2112 , Aug 17, 2020 :
    I have a OnePlus 7 Pro with 12 GB of RAM, and I started noticing a heavy battery drain after the latest update. I used to get 6+ hours and now I am getting 4 to 5 hours on a full charge, so up to a 25% reduction in battery life. The usage has been the same, the only change I have made recently has been installing Google's Messages app for SMS since I believe that iti better than OnePlus' native app. Please follow up with me on this.
    Jagel and U1570531450821 like this.
  5. karim
    Froyo Aug 17, 2020
  6. SillyStrom
    Donut Aug 17, 2020
    SillyStrom , Aug 17, 2020 :
    Can't get any more agree with you all usually we use to get 6 hours of battery life but after the update it has been reduced to barely to 5 hours this is sick really
  7. Artemus.
    Nougat Aug 17, 2020
    Artemus. , Aug 17, 2020 :
    When is the last time you three wiped your phone (AKA "factory reset")?
    ron_R and ASCHENTE_V like this.
  8. SillyStrom
    Donut Aug 17, 2020
    Not a single time..and i dont think it will help it ca cause more problems that is why I don't want to reset
  9. Artemus.
    Nougat Aug 17, 2020
    Actually, a factory reset can fix most issues. Give it a try! All it requires of you is to back up your important stuff to Google Drive.
    ron_R, ASCHENTE_V and SillyStrom like this.
  10. SillyStrom
    Donut Aug 17, 2020
    i will give it a try but i have done something i limited the background app limit so until the next update i can manage this if next time this happened i will do the thing you said thanks bud
    Artemus. likes this.
  11. C1597775031544
    Cupcake Aug 18, 2020
  12. Artemus.
    Nougat Aug 18, 2020
  13. SillyStrom
    Donut Aug 19, 2020
    SillyStrom , Aug 19, 2020 :
    just go to the settings and backround process limit and choose 2 apps process limit you will find the difference and turn off the location permission
  14. Sairam Venkata
    Eclair Aug 19, 2020
    Sairam Venkata , Aug 19, 2020 :
    I am using op 7 after update to 10.3.4 the battery getting drained before update used to get charging for 2 days .Now only 1 day to one and half day.
  15. SillyStrom
    Donut Aug 21, 2020
    SillyStrom , Aug 21, 2020 :
    this update is Worst..Have you feel you Device us getting hot from the top side and battery is charging quickly than before..And drains in quick time
    Sairam Venkata and android_420 like this.
  16. android_420
    Cupcake Aug 27, 2020
    android_420 , Aug 27, 2020 :
    Oh okay, it's good to know I'm not the only one facing these issues. Anybody find any solutions yet? But I updated around two weeks ago and have seen my battery life start to tank. OnePlus 7 Pro used to be able to last me until midnight or later on a full charge, but now can barely get past 5 pm. The charging seems to have gotten faster as well. Nothing on AccuBattery seems to suggest anything else. The battery capacity has certainly gone down, but not out of the ordinary. I think this is definitely a software issue. Thoughts?
  17. Artemus.
    Nougat Aug 27, 2020
    Artemus. , Aug 27, 2020 :
    What're you doing on the phone exactly?
  18. android_420
    android_420 , via OnePlus 7 Pro , Aug 27, 2020 :
    Lately? Not much. I usually leave it on my desk. Admittedly, today, a lot of file transfer via Smash. Will see tomorrow if I can post battery stats when I'm back to more normal use.
    With that said, normal use is usually browsing articles, social media, a little bit of YouTube and, if time permits, gaming.
    I'm usually at 45% brightness at times, using the 'colorful' theme.
  19. Artemus.
    Nougat Aug 27, 2020
    Try changing it to "Nuanced Dark" to see if that helps any.
  20. android_420
    Sure thing. It's just that I've been using the 'colorful' theme before and have had no issues - this has been very recent (and sudden). Will see what happens. Last resort, I'm still under warranty, at least
