89
OnePlus 7 Pro battery/heating feedback thread
  1. Jay2020
    Ice Cream Sandwich Sep 24, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , Sep 24, 2020 :
    It was so easy to get good battery performance when I first got my OnePlus 7 Pro. Now, with each update it has gotten harder and harder ( I mean with having to adjust more things on the phone to get it; app hibernating, screen brightness level, dark mode, battery optimization, etc.). Now many are struggling with Google Play Store sucking a lot of the battery usage ( could be a Play Store issue and not a OnePlus). As of yesterday I'm testing with Google Play Store deactivated, so far so good. Deactivating the Play Store.
  2. Jay2020
  3. F1589716878576
    Cupcake Sep 26, 2020
    F1589716878576 , Sep 26, 2020 :
    I have the same issue. OP7Pro.
    Im delete cache and data from google play store and install newest version from apkmirror (now 22.0.18)
    Observe next few days.
  4. Jay2020
    Ice Cream Sandwich Sep 26, 2020
  5. Sairam Venkata
    Eclair Sep 28, 2020
    Sairam Venkata , Sep 28, 2020 :
    Device is getting hot while charging compared to previous update and battery is getting drained from 95 % to 15 % with in 18 hours . previously when charged to 90% used the device for 2 days without charging .
  6. dinbandhukumar
    Ice Cream Sandwich Sep 29, 2020
  7. Mitesh_Dutta
    Donut Sep 29, 2020
  8. MahfouzRafidi
    Cupcake Sep 30, 2020
    MahfouzRafidi , via OnePlus 7 Pro , Sep 30, 2020 :
    Noticed all of this around this month. Gallery is draining my battery. First picture was while I was sleeping. Second picture was the same day, just towards the end of it. Phone gets hot when charging. I use a OnePlus charger with a OnePlus case. This hasn't changed since I got the phone, but the phone started getting uncomfortably hot out of nowhere. Around the same time this issue began
  9. F1589716878576
    F1589716878576 , Sep 30, 2020 :
    I think i found a solution for Google Play Store draining battery.
    Its second day and everything looks ok.
    - Stop Google Play Store, clear cache and data. Update to v22.0.18 f.ex. from https://www.apkmirror.com/apk/googl...-0-18-21-0-pr-333153705-android-apk-download/
    - Clear data and cache Google Play Services and update: Google Play store > find Google Play Services > Update or install from: https://www.apkmirror.com/apk/googl...-36-15-120400-333172415-android-apk-download/
    - after that, reboot phone.
    After 2 days and one night, Play Store is not on the podium on battery use. Looks like before. Pls, give me a feedback did it work for you.
    OnePlus 7 PRO 10.0.7.GM21BA
  10. Mr.Sheikh
    Mr.Sheikh , via OnePlus 7 Pro , Sep 30, 2020 :
    Exactly 💯
  11. vikas1234567890
    Cupcake Oct 3, 2020
  12. Aarya Deb
    Donut Oct 5, 2020
  13. Luarpc
    Froyo Oct 5, 2020
    Luarpc , via OnePlus 7 Pro , Oct 5, 2020 :
    Disable it, and use Google photos. I don't use oneplus gallery app.
    Aarya Deb likes this.
  14. Jay2020
    Ice Cream Sandwich Oct 6, 2020
  15. sidnir
    Cupcake Oct 6, 2020
    sidnir , Oct 6, 2020 :
    9GAG takes up a lot of battery.
    Usually comes with a warning asking if I want to Force Stop the app.
    Phone heats up as well if I'm browsing 9gag for a significant amount of time.
    Can anyone explain why this happens when using 9gag?
    I'm using OP7Pro 12/256GB, Open Beta 18 build, security patch Sept 2020.
  16. Artemus.
    Nougat Oct 6, 2020
    Artemus. , Oct 6, 2020 :
    Simple: don't use 9gag. Use the site itself where it's not usurping resources.
  17. Dharmay Sureja
    Cupcake Oct 6, 2020
    Dharmay Sureja , Oct 6, 2020 :
    My Oneplus 7 pro gives average screen on time of 3-4 hours
    Wifi is always on
    Bluetooth on but not connected always
    location on always
    no heavy task
    mostly whatsapp, YouTube and other social media stuff
    battery life is very poor
    and charging time is also quite high (1.5 hours)
  18. Artemus.
    Nougat Oct 6, 2020
    Are you boasting or complaining?
  19. Dharmay Sureja
    Cupcake Oct 6, 2020
  20. Artemus.
    Nougat Oct 6, 2020
    Here's your problem then: "location on always".
    If you have no reason to have it on, turn it off.
    Jay2020 likes this.
