102
OnePlus 7 Pro battery/heating feedback thread
  1. Dharmay Sureja
    Cupcake Oct 6, 2020
    Dharmay Sureja , Oct 6, 2020 :
    Sure i will try
  2. Jay2020
    Ice Cream Sandwich Oct 6, 2020
    Jay2020 , via OnePlus 7 Pro Nebula Blue , Oct 6, 2020 :
    said:
    Turn off all data to Gallery.
  3. Jay2020
    jim.kanaris likes this.
  4. Gopi8189
    Froyo Oct 7, 2020
  5. Jay2020
    Ice Cream Sandwich Oct 7, 2020
  6. Aarya Deb
    Donut Oct 8, 2020
    Jay2020 likes this.
  7. Fatact
    Cupcake Oct 9, 2020
    Fatact , Oct 9, 2020 :
    Hello I'm using a 7 Pro, I reinitialised it 2 weeks ago because I thought my battery was very bad, but it didn't change anything. This morning I took my phone at 100%, but in using it 22 minutes on 10 hours, I lost almost 39%. I forced optimization on many apps, installed auto-switch Hz, dark theme... But the battery is still very bad. I can't activate airplane mode when my phone is on standby because I often have to check my messages.
    I'm running on the beta 18 but there is no difference with the alpha.
    I don't know if this big battery consumption is normal but it is in any case very annoying to end the day. If you need more detail or have some tips I'm ok :).
    On accubattery, it was said that my battery was at 87% of its total capacity, I have this phone since its release one year ago.
  8. Artemus.
    Nougat Oct 9, 2020
    Artemus. , Oct 9, 2020 :
    When did you last format?
  9. Fatact
    Cupcake Oct 9, 2020
  10. Atulbamane
    Cupcake Oct 10, 2020
  11. Aryan_j
  12. Artemus.
    Nougat Oct 10, 2020
    Artemus. , Oct 10, 2020 :
    That's... good? At least you know why you're getting that, I suppose?
  13. ErronGhost
    ErronGhost , via OnePlus 7 Pro , Oct 10, 2020 :
    Is anybody having issues related to their battery drain recently regarding the Gallery Photos app?? I'm getting above 20% usage all day not even using it.
    As soon as i unplug my phone from charger in the morning, i get to 90% in less than 30min without using it at all (standby).
    I tried looking on the net for guides and tips but no one can answer a solid solution, just asking for more answers.
    Methods tried:
    Brightness
    Resolution
    Refresh Rate
    Logging out apps/Uninstalling
    Unsync Google Photos
    Disabled Pre-Installed Apps
    Optimize Apps in Battery Settings
    NONE WORKED!!! This is starting to get annoying after connecting the phone up to 5 times a day!!
  14. Artemus.
    Nougat Oct 10, 2020
    That's completely normal. 100% isn't truly 100% a lot of the time.
  15. aasim9808
    Donut Oct 11, 2020
  16. Aryan_j
    Cupcake Oct 11, 2020
  17. Gopi8189
    Froyo Oct 11, 2020
    Gopi8189 , via OnePlus 7 Pro , Oct 11, 2020 :
    This work perfectly
  18. GokulLee
    Gingerbread Oct 12, 2020
  19. G1583623447398
    Cupcake Oct 14, 2020
    G1583623447398 , Oct 14, 2020 :
    Hello,
    i have a problem with bettery life. Something is draining battery but i cannot find what. Today SOT was 3h 15 min which is very poor, because i didn't even use any heavy application. I tried wiping cache, and also i installed newest beta but without any luck. Should i hard reset my phone? I have it for 6 months now. Screenshot_20201014-194515.jpg
