120
OnePlus 7 Pro battery/heating feedback thread
  1. AmarSah
    Froyo Dec 4, 2020
  2. _Bharat_
    Gingerbread Dec 4, 2020
  3. Artemus.
    Community Hero 2020 Dec 5, 2020
    Artemus. , Dec 5, 2020 :
    There's no such thing as "overcharging".
  4. Rahultech
    Eclair Dec 5, 2020
  5. Elvis2020
    Cupcake Dec 5, 2020
    Elvis2020 , via OnePlus 7 Pro , Dec 5, 2020 :
    Lower the screen resolution, lower down the screen refresh rate if u have a 90 hz or 120 hz capable phone. Try force stopping any unwanted apps or apps not in use
  6. AmarSah
    Froyo Dec 5, 2020
  7. AmarSah
    Froyo Dec 5, 2020
  8. HUNTERPRINCE
    Eclair Dec 5, 2020
  9. Hitzilla4
    Gingerbread Dec 5, 2020
  10. Amrish572
    Donut Dec 6, 2020
  11. Raj4oneplus
    Cupcake Dec 6, 2020
  12. Zenith69
    Cupcake Dec 6, 2020
    Zenith69 , Dec 6, 2020 :
    My phone used to go to deep sleep after a few minutes to save battery, but from Dec 2 it's not going into deep sleep anymore, even tho I've been using the phone in the same way as before. Did not install any new apps or any update. How do I fix this?
  13. AdityaMagdum108 , via OnePlus 7 Pro Mirror Gray , Dec 7, 2020 :
    If not required turn off the WiFi and the location feature. Also schedule the turning on of battery saver at whatever level you require. Night mode can be scheduled to turn in at sunset. These small steps may help you body your battery in an efficient way. Play games at scheduled time so that the RAM can predict the usage at that particular time and accordingly dedicate the required strength for playing.
  14. Kuljeet23
    Cupcake Dec 7, 2020
  15. Zenith69
    Cupcake Dec 7, 2020
    Zenith69 , Dec 7, 2020 :
    that doesn't solve my problem, my problem is my phone isn't going into deep sleep. I tried turning on battery saver and turning wifi and everything off still no result. And schedule gaming? Am I using my phone or my phones using me? that doesn't make sense
  16. Rahultech
    Eclair Dec 7, 2020
    Rahultech , via OnePlus 7 Pro , Dec 7, 2020 :
    Thanks bro
  17. AdityaMagdum108 , via OnePlus 7 Pro Mirror Gray , Dec 7, 2020 :
    Then the next steps may be useful to you.
    1) shift your refresh rate to 60Hz
    2) turn on adaptive brightness or rather set it low levels
    3) shift your display settings to normal rather than Vivid
    4) at night turn on greyscale mode
    5) schedule power off and power on when you go to sleep
    6) enable DC dimming
