23
OnePlus 7 pro bugs
  1. sentamil397
    Cupcake May 21, 2021
    G_Suraj_Kumthekar likes this.
  2. sentamil397
  3. sanketbajoria
    Eclair May 21, 2021
    sanketbajoria , via OnePlus 7 Pro , May 21, 2021 :
    I am also facing the same problem
  4. sanketbajoria
    Eclair May 23, 2021
  5. Artemus.
    Community Hero 2020 May 23, 2021
    Artemus. , May 23, 2021 :
    Completely safe.
  6. sanketbajoria
    Eclair May 23, 2021
  7. Artemus.
    It's more than likely a hardware problem then.
    Shailender Sharma likes this.
  8. sanketbajoria
    Eclair May 23, 2021
  9. Artemus.
    Again, hardware problem.
  10. sanketbajoria
    Eclair May 23, 2021
  11. Edit.phactory
    Cupcake May 23, 2021
    Edit.phactory , via OnePlus 7 Pro , May 23, 2021 :
    I was also facing this issue. I have a setting for the same. And it helped me out. you can also try that too. Maybe it can help you if not then do let me know. will find something else. But for now
    - Go to wifi settings
    - then click on the wifi preferences option
    - there you will a setting name "INTELLIGENTLY SELECT THE BEST WI-FI "
    - You can disable this feature
    Because the phone is continuously searching for wifi, and as soon as it finds a strong network connection than yours, it disconnects the current WiFi you are connected with and try to connect with that wifi, now you don't have the password of that wifi saved, so the phone gets confused and final result is, it stays disconnect with any wifi... I hope this will resolve your issue. .
  12. Edit.phactory
    Pamela0804 likes this.
  13. Pamela0804
    Cupcake May 24, 2021
    Pamela0804 , via OnePlus 7 Pro , May 24, 2021 :
    I'm going to try it and let you know thank you
    Edit.phactory likes this.
  14. harshgupta2214
  15. Edit.phactory
    Edit.phactory , via OnePlus 7 Pro , May 24, 2021 :
    Have you tried clearing your cache from GOOGLE PLAY SERVICE AND RECOVERY MODE ?
  16. royce dias
    Cupcake May 27, 2021
    royce dias , via OnePlus 7 Pro , May 27, 2021 :
    At the first update of android 11 my front camera stopped working and now after the second update my back camera too has stopped working and it says it has a hardware issue. Where as before the update I have clicked pictures and just after the update not even the camera and flashlight Is working. My 7pro has become a trash now. I will not invest anymore in oneplus very bad experience with 7pro.
  17. sanketbajoria
    Eclair May 27, 2021
    sanketbajoria , via OnePlus 7 Pro , May 27, 2021 :
    True bro i am also planning to switch to some other company i am also facing the same problem.
    The difference is that my back camera is working but not the front camera.
    Chrisvar likes this.
  18. royce dias
    Don't update or else the back camera too will stop working. Same happened to me.
    #38
  19. sanketbajoria
    Eclair May 27, 2021
    #39
  20. F_Popescu_George_BfsN
    F_Popescu_George_BfsN , May 27, 2021 :
    Hello. After the last update, the battery drains so fast. The weird thing is that I'm not using the phone as much i used to in past, but still with no succes for the battery life. Some apps crash for no reason. This is my third OP device and but with these recuring problemes it will very well be the last one.🤦🏻‍♂️
    #40
    sentamil397 likes this.
