23
OnePlus 7 pro bugs
  1. Artemus.
    Community Hero 2020 May 27, 2021
    Artemus. , May 27, 2021 :
    Battery graphs help, my dude.
    #41
  2. S1582285516782
    Cupcake May 28, 2021
    S1582285516782 , via OnePlus 7 Pro , May 28, 2021 :
    I am facing issues while taking extended screenshots. The phone just gets freezes up and nothing happens after. Even the phone hangs up while using extended screenshot feature
    #42
  3. sanketbajoria
    Eclair May 28, 2021
    sanketbajoria , via OnePlus 7 Pro , May 28, 2021 :
    This feature can be done over very limited app and page.
    #43
  4. AndreiBorsa9087
    #44
  5. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert May 28, 2021
    #45
  6. Abhi_RightNow
    Froyo May 29, 2021
    Abhi_RightNow , via OnePlus 7 Pro , May 29, 2021 :
    It's working fine after the last update
    #46
  7. Ankita_S.
    OnePlus Bug Hunter Staff Member May 31, 2021
    Ankita_S. , May 31, 2021 :
    We would like to check this further and have got in touch with you via personal conversation for more details.
    Please requesting you to respond to us at the earliest.
    Regards,
    Ankita
    #47
  8. Ankita_S.
    Regards,
    Ankita
    #48
  9. Chrisvar
    Cupcake Jun 1, 2021
    Chrisvar , via OnePlus 7 Pro , Jun 1, 2021 :
    I also can't send quick messages to my conversations through the notification bar. Device lags terribly, is now buggy, and the touch is often unresponsive within third party applications.
    Is there any way I can revert back to the last working update OS 10? This device used to be so good but now it's causing me nothing but pain.
    #49
    G1622222862727 likes this.
  10. #50
  11. #51
  12. #52
  13. samppahey
    Cupcake Jun 5, 2021
    #53
  14. #54
  15. samppahey
    Cupcake Jun 6, 2021
    #56
  16. TxGopi
    Gingerbread Jun 6, 2021
    TxGopi , via OnePlus 7 Pro , Jun 6, 2021 :
    Facing this problem bro
    #57
  17. lud32
    Cupcake Jun 7, 2021
    lud32 , via OnePlus 7 Pro , Jun 7, 2021 :
    So I just had the 2nd android 11 update. The version number is 11.0.1.1 gm21ba. The phone started lagging like never before. Unlocking the screen took a good 15 seconds of waiting without using the fingerprint. With it it never did as it would get stuck on scanning it. Apps were laggy as well. So clearly OP are slacking major time when it comes to software updates which is looking really really bad for them. But I found 2 potential fixes that may work for anyone that has these issues.
    Steps:
    1 tun off the device
    2 press the volume down and power key to power it back up
    3 release the power key but not the volume down one
    Keep holding that one until you see the OP logo in black and white and a keyboard foe you to type.
    4 type in your phone password (the one you use to unlock it. If you have a pin like me use that) and click ok at the bottom right when you are done
    5 select English
    6 select wipe data and cache
    7 select clear cache
    8 confirm with yes and wait for the device to reboot.
    9 if these steps fail try doing a factory reset but make sure you backup your data just to be safe.
    Steps 1-8 is what I did and it worked for me. I have no more lags or issues. Hope this helps if anyone is still struggling.
    #58
  18. RAHUL_VIJAYY
    Froyo Jun 7, 2021
    #59
  19. Artemus.
    Community Hero 2020 Jun 8, 2021
    Artemus. , Jun 8, 2021 :
    Alright. Download CPU-Z from the Play Store and screenshot the thermal tab. Also, when did you last wipe your phone?
    #60
    Shailender Sharma likes this.
