Oneplus 7 Pro car Dash charger problem
  1. subenieko
    Cupcake Aug 22, 2019
    subenieko , Aug 22, 2019 :
    Hi, my car Dash charger doesn't charge my OP 7 Pro at dash speed. It turns on dash and turns it off instantly every 10 seconds or so. Anyone had the same problem and knows what is wrong?
    Here is the screen capture, where phone is connected to car dash charger all the time:
  2. J1566390033913
  3. subenieko
    I guess this was supposed to be a joke (PC On/Off?:)), but I did try it and nothing changed.
  4. xnutzii
    Lollipop Aug 22, 2019
    xnutzii , Aug 22, 2019 :
    You can try to check if either your 12V port of the car is clean, and if the cable/port where the cable connects has little to negligible dust. If this is the case, you may have gotten a faulty car charger. You own any other OnePlus phone? If so, test this out eventually, too.
  5. subenieko
    I don't have my old Oneplus 5, sadly, so I can't check if it works on other phones. I will try to clean the connection tomorrow.
