OnePlus 7 Pro Front camera not Working
  1. rgvd1987
    Gingerbread Sep 13, 2020
    rgvd1987 , Sep 13, 2020 :
    Hello.. I am using one plus 7 pro for the last 12 months. Day before yesterday my front pop up camera suddenly stopped working. It pops out.. Stay out for few second and then goes back inside. At the same time camera UI also crashes. I tried clearing cache, data.. Tried Gcam.. But to no use.. I also did factory reset twice but no luck.. My camera version 3.10.24 and my phone is on 10.3.4GM21AA. Please suggest a solution before i go to repair.
    Thanks in advance
  2. rgvd1987
    Gingerbread Sep 15, 2020
  3. ROGERIO PUERTO
    Cupcake Sep 22, 2020
    ROGERIO PUERTO , Sep 22, 2020 :
    Hi, can you solve the problem? I have the same problem
  4. C1600830362366
    Cupcake Sep 23, 2020
    ROGERIO PUERTO likes this.
  5. K1564619356317
    Cupcake Oct 17, 2020
  6. Diogo Lucas de Oliveira , via OnePlus 7 Pro , Oct 17, 2020 :
    I am facing the same problem. Initially the front camera opened but a few seconds later it closed. The back worked until I restarted the smartphone. Now none of them work in any of their own or third-party applications. Please, does anyone have a solution?
  7. Ronak3567 , via OnePlus 7 Pro Nebula Blue , Oct 18, 2020 :
    Download fresh firmware from Oneplus website and place it in sd card without any folder and then try to install that ipdate from Settings> system> system updates> local upgrade
    Just a suggestion and may erase ua data i dont know just suggesting a way
  8. #8
  9. Diogo Lucas de Oliveira , via OnePlus 7 Pro , Oct 18, 2020 :
    I already did and it didn't solve it. In fact, I downgraded it to OOS 9 and the rear cameras worked, the front one didn't. I returned to the OOS 10 clean flash and none of the cameras worked.
  10. Ronak3567 , via OnePlus 7 Pro Nebula Blue , Oct 18, 2020 :
    Is it still not working..? Or u solved it any how if yes what did u do? If no what r u waiting for go get ua device repaired it from OnePlus service center it may b hardware issue
  11. Vivekrvcse
    Cupcake Oct 24, 2020 at 1:01 PM
  12. Fenelon_dr
    Cupcake Oct 25, 2020 at 6:47 AM
