OnePlus 7 pro Front camera not working via OnePlus 7 Pro
  1. B1578302377884
    Cupcake May 25, 2021
    B1578302377884 , via OnePlus 7 Pro , May 25, 2021 :
    Front camera not working, tried clearing camera cache, uninstalling apps, nothing works.
    Currently on 11.0.1.1 update
    Can't open all apps that work with front cam, whatsapp, snapchat are not working.
    Nihal ozcicek likes this.
  2. #2
  3. J4t1np4r3kh
    OnePlus Accessory Tester May 26, 2021
  4. D1560375760435 , via OnePlus 7 Pro , May 26, 2021 :
    I have done that. They just tell you to wipe data and cache then do a factory reset. Which doesn't work. So then they want you to send it in for repair. Which will cost. Seems odd that a new update can cause a hardware issue that will cost me money to fix. It's not just me either. Many other reports about this issue
    Rashi_Bajaj and B1578302377884 like this.
  5. shatakshi_modi
    Cupcake Jun 3, 2021
    shatakshi_modi , Jun 3, 2021 :
    I have the exact same issue, the customer care person told me to perform the exact same steps, and I was told to get my phone checked too
    B1578302377884 likes this.
  6. B1578302377884
    Cupcake Jun 3, 2021
    B1578302377884 , via OnePlus 7 Pro , Jun 3, 2021 :
    There is lockdown in India right now, all the service centers are closed. Factory reset , clearing cache, latest update (version 11.0.1) aren't working. There is no service center open to get this fixed.
  7. shatakshi_modi
    Cupcake Jun 3, 2021
    shatakshi_modi , via OnePlus 7 Pro , Jun 3, 2021 :
    I just contacted OnePlus customer care they said they are working on the issue, and will have the patch update out soon
  8. B1578302377884
    Cupcake Jun 3, 2021
  9. Abhi_RightNow , via OnePlus 7 Pro , Jun 3, 2021 :
    I think it's fine now
  10. H1559958880338
    Cupcake Jun 4, 2021
    H1559958880338 , via OnePlus 7 Pro , Jun 4, 2021 :
    Same issue, front camera popping up but nothing is displayed. Back camera working fine. Tried with multiple apps - camera, whatsapp etc. Face unlock doesn't work too.
    OS: 11.0.1.1
    Region: India
  11. A1622815443634
    Cupcake Jun 4, 2021
  12. A1622815443634
    Cupcake Jun 4, 2021
  13. K1620135098822
    Cupcake Jun 6, 2021
  14. Abhi_RightNow , via OnePlus 7 Pro , Jun 6, 2021 :
    Service centre should have a solution
  15. Q1577331415421
    Cupcake Jun 8, 2021
  16. samveghi
    Cupcake Jun 8, 2021
  17. #17
  18. Drupad Vyas
    Eclair Jun 11, 2021
    Drupad Vyas , via OnePlus 7 Pro , Jun 11, 2021 :
    Same problem after updating tp latest update.
    Front camera pop ups and the screen goes blank.
    Can't do anything apart from Only force close app.
    Did factory Rest - didn't help.
    Customer care not providing timeline for resolution.
    They said wait till next update.
  19. Abhi_RightNow
    Froyo Jun 12, 2021
    Abhi_RightNow , via OnePlus 7 Pro , Jun 12, 2021 :
    Got the same response from them :(
  20. B1578302377884
    Cupcake Jun 13, 2021
