OnePlus 7 pro global gm1917 screen flickering (green tint) and stuck pixel via OnePlus 7 Pro
  1. vines_zach
    Froyo Jan 6, 2020
    vines_zach , via OnePlus 7 Pro , Jan 6, 2020 :
    so I've been buying OnePlus phone since 2014 when they came out and I've never had a problem with any of the phones. however I bought the OnePlus 7 pro when they had the promotion last month and I received it on the 19th or 20th of December. I haven't had the phone for more than a month now and I'm already experiencing screen issues. I went to sleep normal with my phone charging and woke up the next day and I had a stuck/hot pixel on my far left side of screen and out of nowhere halfway through the day the screen started flickering on the bottom half with a green tint to it, reacting to the stuck/hot pixel. has anybody seen anything like this or know how to fix it? any information will be extremely helpful guys thanks
    Abhi goswamy likes this.
  2. Swejuggalo
    Lollipop Jan 6, 2020
    Swejuggalo , Jan 6, 2020 :
    I'm pretty sure this is a hardware issue. You may need to get it replaced or repaired
    Artemus. likes this.
  3. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Community Expert Jan 6, 2020
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 6, 2020 :
    (if it persists in all screens and during reboot as Bouncer71 said)...
    I also noticed some green symbol to the left upper corner. Some active call or some app adding that?
    Bouncer71 likes this.
  5. vines_zach
    Froyo Jan 6, 2020
    I've rebooted a couple times as well as rebootjng into safe mode but it's there no matter what, since it started it hasn't gone away even for a split second. I have a video of it but it won't let me post it. also the green call logo was because I had OnePlus support on the line and was seeing what they could do for me. should be getting a call back today
  6. vines_zach
    Froyo Jan 6, 2020
  7. Bouncer71
    Bouncer71 , Jan 6, 2020 :
    Well then it certainty sounds like a hardware defect if it's also present on boot...
  8. J1572039149975
    Cupcake Jan 7, 2020
    J1572039149975 , Jan 7, 2020 :
    Did your issue resolve...I m facing the same problem on OnePlus 6t after Android 10 update but my tint color is black.
  9. vines_zach
    Froyo Jan 23, 2020
    vines_zach , via OnePlus 7 Pro , Jan 23, 2020 :
    no issue is still persistent. and OnePlus customer support said that because I was 2 days past my "return window" that I would have to pay for a new screen out of pocket... bunch of BS -_-
  10. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 23, 2020 :
    What have return windows anything to do with warranty? Warranty should still apply right?
  11. vines_zach
    Froyo Jan 24, 2020
  12. vines_zach
    Froyo Jan 24, 2020
    vines_zach , via OnePlus 7 Pro , Jan 24, 2020 :
    can you post a picture?
  13. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 24, 2020 :
    Would never have been a problem if it happened for me. I would just turn in the phone and have it repaired or replaced by my carrier (the whole first year). And if it actually turns out to be damaged by a drop or something I can use my insurance to get it replaced by a new phone within 2 days or so.
    So in your case warranty does not even exist this close to purchase? Sounds odd to me...
  14. JmcRepair33
    Ice Cream Sandwich Jan 24, 2020
    JmcRepair33 , Jan 24, 2020 :
    usually ahppens when water gets inside, as a tech im pretty sure that could be it and flickering, , have the phone checked for water damaged, also not cocvered under warranty if it has water damage
  15. U1559047854368
    Cupcake Jul 4, 2020
    U1559047854368 , Jul 4, 2020 :
    Hi,
    I have this problem too. I sent it back to the service, they say it is not under warranty, it would be repaired for more than 200 euros. The phone has a 2-year warranty, the screen error occurred from one moment to the next. The problem was not my fault.
    What happened to you?How did it work out for you?
    Thanks in advance.
  16. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 4, 2020 :
    If it's just the screen going bad with no exterior damage... Warranty.
    If it has happened with moisture indicators having turned red... No warranty.
  17. T1589842223055
    Cupcake Aug 5, 2020
    T1589842223055 , Aug 5, 2020 :
    conseguiu resolver? Eu tenho o mesmo problema ... Fiquei me perguntando se a única solução é mudar a tela?
