OnePlus 7 pro inside freezer via OnePlus 7 Pro
  1. Sriram94617
    Gingerbread Mar 25, 2020
    Sriram94617 , via OnePlus 7 Pro , Mar 25, 2020 :
    Hi if I take my OnePlus 7 pro inside a freezer with a temperature of -15 degrees will it have some negative effect on the phone, like for the battery and other internals?
  2. herget
    Froyo Mar 25, 2020
    Liehjan likes this.
  3. Matt 80
    Lollipop Mar 25, 2020
  4. Liehjan
    Liehjan , Mar 25, 2020 :
    Ever heard about condensation? Don't do it or you might end up with a dead device
    B_Wrath likes this.
  5. Sriram94617
    I am working part time at a supermarket which has a freezer where I have to go inside the freezer sometimes to check out the stock
  6. Cheetosdust
    Starting Point Expert Community Expert Mar 25, 2020
    Cheetosdust , Mar 25, 2020 :
    I don't know, perhaps don't treat your OnePlus 7 Pro like cookie dough?
    And to answer your follow-up question: no, taking it out of the freezer and give it five minutes on the microwave is also not recommended. :rolleyes:
  7. StopItRawr
    Ice Cream Sandwich Mar 25, 2020
  8. Sriram94617
    thanks for ur wisdom
  9. Cheetosdust
  10. Sriram94617
    it's not like I took it on purpose , I just forgot to take it out while going inside the freezer
  11. Liehjan
    Your device will be fine, just keep it in your pocket wile in the freezer... I have used my phone in -30 degrees without any issues... Battery may drain faster, but other than that you won't have issues, it's not like your are in the freezer for 8hrs straight
    Sriram94617 likes this.
  12. Swejuggalo
    Swejuggalo , via OnePlus 7 Pro , Mar 25, 2020 :
    I need to enter fridges every now and then. If I need to enter longer than just a few seconds I have the phone in a breast pocket under a winter jacket.
    I used to work at a place with extreme heat too. Then they had a lot of Siemens M65 phones. All of them died. Mine may have died faster due to reversing over it with my car though. But it made it and lived after that too [e]1f609[/e]
    luigimario likes this.
  13. BigT Texas
    Eclair Mar 27, 2020
    BigT Texas , Mar 27, 2020 :
    one thing you can do is keep the phone next to your body. your body heat will keep it warm. like an inside pocket or something inside your jacket. [e]1f44d[/e]
    Big T
