4
OnePlus 7 Pro Lag Problem and Frame Drop Issue
  1. Prosweet
    Eclair Sep 20, 2019
    Prosweet , Sep 20, 2019 :
    I have Lag problems on my OnePlus 7 Pro. it stucks very hard on Google maps, Netflix, YouTube or switching one app with other or surfing in the internet. This started after I switched on the smart lock option. One day I get my Phone out of my pocket and I saw that smart lock opened the phone and it entered very different settings on developer options like logkit etc. After that day the phone that I haven't seen any lag crumb, become very laggy. Can anyone help please...
    Sincerely Community, love you all...
  2. Prosweet
    Eclair Sep 20, 2019
  3. Prosweet
    Eclair Sep 21, 2019
  4. Cervantes
    Moderator Moderator Sep 21, 2019
    Cervantes , Sep 21, 2019 :
    Hi
    You had factory reset
    How did you install the applications:
    backup copy
    from play store
  5. Prosweet
    Eclair Sep 21, 2019
    Prosweet , Sep 21, 2019 :
    Cervantes
    Hi
    backup copy
    from play store​
    thanks for your response.
    I downloaded all of the apps from Google play store and I had factory reset 2 times.
    But it's not about only the applications for example: I'm in an application like YouTube and I press the home button then it hangs-up a bit and stucks while it comes the home screen. Or on the internet I swipe down or up the page and the frame rate is dropping. Think this like that: You are in a game and you play with the 10 FPS. How it stucks? This seems like that
    thanks for your time...
  6. Cervantes
    I suggest a clean installation
    Today they published Android 10
    When they upload the rom zip on the support page
    You download it and perform a clean installation
  7. Prosweet
    Eclair Sep 21, 2019
    Cervantes
    You download it and perform a clean installation​
    I was wishing like you: Update to the android Q will solve it.
    Actually it's my last hope.
    OK. Thank you..
  8. shelvin93
    Cupcake Sep 27, 2019
    shelvin93 , Sep 27, 2019 :
    I'm facing some general lagging issues on my oneplus 7pro as well. Sometimes with Chrome and maps and other apps in general. Any solution to this identified?
    azl_an_ likes this.
  9. Prosweet
    Eclair Sep 29, 2019
    Prosweet , Sep 29, 2019 :
    I have reseted the factory settings and clean the cache for the problem that you are facing. Now better
  10. #10
  11. Prosweet
    Eclair Oct 4, 2019
    Prosweet , Oct 4, 2019 :
    Hi dude!
    If these lags are displeasing you that much I suggest you to reseting to the factory settings and clear the cache.
    I think the main problem of the lags are this: Phone is not stabilized with applications like Chrome or Google maps. Because the stock applications doesn't cause the same lag problems.
    I hope they fix it and conform with all of the apps on Android Q
    Sincerely...
    Chiranjeevi Sai Ram K likes this.
  12. T1569574755236
    Cupcake Oct 5, 2019
    T1569574755236 , Oct 5, 2019 :
    as stated throughout the day, it will suddenly lag in recent apps and between homescreens. it will do this no matter what until it decides to dissapear on its own. its super frustrating. anyone suffering from this?
    W1572187700893 likes this.
  13. pgrey
    Ice Cream Sandwich Oct 7, 2019
    pgrey , Oct 7, 2019 :
    @T1569574755236 What app(s) are allowed to "run in the background", of the "3rd party apps" you've installed?
    I'd bet one-or-more of these is the issue, hands-down.
    If you boot into "Safe Mode", you can test this easily-enough, see if you have "any lag" when in Safe Mode?
    I'm curious to hear your reply, thanks.
  14. W1572187700893
    Cupcake Oct 27, 2019
    W1572187700893 , via OnePlus 7 Pro , Oct 27, 2019 :
    yes even I am facing the same issue. is there any way out?
  15. W1572187700893
    is it a stable fix? are you facing the same issue now as well?
  16. Prosweet
    Eclair Nov 4, 2019
    Prosweet , via OnePlus 7 Pro , Nov 4, 2019 :
    Hi dude!
    Sorry for responding late :(
    It didn't fixed completely but more fluid and I realized that it's better on Android Q than the 9. Chrome still has some bugs and stucks but the Google app (for surfing on the internet) is completely fixed and it's all 90hz. So I generally use the Google app not Chrome. Also I tried some kind of devices -Xiaomi MI 9T, Samsung galaxy A70- to test the screen experience and fluidity because they use 60hz panel. According to we who get used to 90hz panel they seems so laggy. So I decided that because of we get used to use 90hz any crumb of lag displeasing us.
    As I told you at the beginning the apps are not fixed completely especially the Chrome, maps and some sort of them but it's ok for now. I hope they develop this
    I hope you have fun using your OnePlus 7Pro!..
    Sincerely...
  17. Endruuu
    Gingerbread Jan 21, 2020
    Endruuu , Jan 21, 2020 :
    same here. first noticed it in chrome, scrolling would sometimes just stop, but also apps in general affected
  18. Endruuu
  19. casiocas7677
    Cupcake Feb 18, 2020
    casiocas7677 , Feb 18, 2020 :
    Hey!
    You can try this one. IT HELPED ME OUT FROM LAGGING!
    https://forum.xda-developers.com/showpost.php?p=81796603&postcount=68
  20. #20
    casiocas7677 likes this.
