5
OnePlus 7 Pro Loses Network Connection - requires reboot
  1. wardekar
    Cupcake Aug 28, 2019
    wardekar , Aug 28, 2019 :
    I have a consistent issue with my OnePlus 7 Pro where if I am driving and using Waze, at some point within about 20 minutes, I lose network connectivity. WiFi can be off or on and the phone is connected via BT to my car. Waze starts displaying "Searching for Network". Turning Airplane mode on and off will not restore connectivity. A full reboot will fix it until the next time it happens. I have tried wiping the cache. This only happens while driving and within about 5 - 10 miles from where I live while using Waze. If I am just at home all day, or drive without using Waze, it does not seem to happen. This is on AT&T, 8GB version running Oxygen OS v 9.5.11
  2. F1561794602982
    Eclair Aug 29, 2019
    F1561794602982 , Aug 29, 2019 :
    I've made sure that data was set to unlimited for the appropriate apps. I've now gone into Developer settings & data is now on permanently to enable faster switching from WiFi to mobile data. Seems to work as I've no longer any issues in the car using AA (latest version) & voice control, music, navigation etc.
  3. Abhisheksahu
    Eclair Aug 29, 2019
    Abhisheksahu , Aug 29, 2019 :
    in India BSNL VoLTE is not supported by OnePlus Devices where as in MI and Redmi Phones are supporting VoLTE of BSNL India network.
    Si it has to be addressed in next incremental update.
  4. Galsuser
    Donut Aug 29, 2019
    C1572425144097 likes this.
  5. K1559951646187
    Cupcake Sep 20, 2019
    K1559951646187 , Sep 20, 2019 :
    Not sure what the fix is but I have a very similar issue I will suddenly lose network when driving no bars all is fine after a restart been happening since launch help please!
  6. wardekar
    wardekar , Sep 20, 2019 :
    I have narrowed this down to the BT stack in my Infiniti M Series which is about 8 years old. This only happens when connected to BT in my car. I have flown to other states and used rental cars with newer BT stacks and this does not happen.
  7. rytomizawa
    Donut Nov 19, 2019
    rytomizawa , via OnePlus 7 Pro , Nov 19, 2019 :
    I have the same problem, and also when I get in the car, but mine is a 2017bmw... the tech behind a 2017 car is already old? why there is no feedback from OnePlus for this issue, it's so annoying having to restart the phone to have data network's back.
  8. rytomizawa
    Donut Nov 19, 2019
  9. P1578306817146
    Cupcake Jan 7, 2020
    P1578306817146 , Jan 7, 2020 :
    I have a OnePlus 7 Pro, located in Denmark, and I am loosing network connections daily. I have restarted the phone, have the last update on it.. i had a oneplus 6 before, that had no issues, this network issue is not satisfying. I might just contact my vendor and say I can not use it.
  10. PatrickRupp
    Cupcake Feb 23, 2020
    PatrickRupp , Feb 23, 2020 :
    I have the same problem!!!!!!
  11. Swejuggalo
    Lollipop Feb 23, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 23, 2020 :
    I had a connectivity issue once. In my case I could easilly replicate it (both mobile and wifi lockout in certain situations). I reported with the feedback tool and next update my issues were solved (using beta channel).
  12. PatrickRupp
    Cupcake Jun 25, 2020
    PatrickRupp , via OnePlus 7T , Jun 25, 2020 :
    Please since i bouth my oneplus 7t i have this problem when i use waze. My network is gone and i need to reebot my phone. I have the latest update and dont fixed that problem. Please Someone can help me? Oneplus, where are you?????
  13. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 25, 2020 :
    Do you happen to use a work profile too? I recall a other user that got issues due to work profile.
  14. PatrickRupp
    Hi. No. I thought that with the latest updates this problem would be solved but nothing. every time I use Waze or Google maps the cell signal drops
  15. Swejuggalo
    Lollipop Jun 25, 2020
    Swejuggalo , Jun 25, 2020 :
    I have never been able to replicate this on either 7 Pro or 8 Pro.
    In one case it happened for a users simply after having a work profile (not actually when really using an app in the profile... It was enough that the profile existed)
  16. Baleeroon
    Cupcake Jul 2, 2020
    Baleeroon , Jul 2, 2020 :
    I have 7T for several days. Behaviour is the same as others describe in this thread.
    In my case whene I changed preffered network type from 2g/3g/4g to 2g/3g problem doesn't occur
  17. PatrickRupp
    Cupcake Jul 2, 2020
    PatrickRupp , via OnePlus 7T , Jul 2, 2020 :
    please, this is very annoying. Oneplus send an update to fix this. i already had op5, op6 and now i'm in op7t. and that problem has been a long time since I bought it. help me eu
  18. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 2, 2020 :
    If you haven't done it yet report it and record the incident/issue and send in the logs via the feedback tool.
  19. PatrickRupp
    Cupcake Jul 2, 2020
  20. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jul 2, 2020 :
    Home in community app. Press the red button. Select feedback. Select cathergory that fits your issue. Write down as much info you can. Depending on type of report you can collect logs or start a recording so you can replicate the issue and then stop the recording when it has been done.
