OnePlus 7 Pro: Lost Mobile Internet Connection after receiving MMS Message
  1. Z1543866223581
    Cupcake Nov 15, 2019
    Z1543866223581 , Nov 15, 2019 :
    Dear OnePlus Community,
    need a solution for following issue:
    everytime I receive a MMS for example a picture my mobile internet connection is disconnected for a while additionally a "!" appears next to the mobile connection sign. If I do nothing it gets back after a while and my only work-around is to disconnect mobile transfere manually and re-connect it.
    First I suspected a failure with my sim card A1 Austria, but since I used the phone in Thailand with AIS and a different sim same failure appeared.
    So I think it is a certain setting that disconnects my mobile internet upon receiving a MMS.
    Does anyone have the same issue? All setting by my provider a acurate and checked.
    @OnePlus: Need support!
    Thank You,
    Greg
