8
Oneplus 7 pro mic disturbance
  1. Neelash
    Cupcake Oct 3, 2019
    #41
  2. abdulsameem
    Cupcake Nov 17, 2019
    abdulsameem , Nov 17, 2019 :
    I am facing the same issue... This happen in regular voice calls and any data or video app calls...
    #42
  3. AdamHinds
    Eclair Nov 20, 2019
    AdamHinds , via OnePlus 7 Pro , Nov 20, 2019 :
    my problem still ongoing months down the track. this will be my last OnePlus device I ever buy. real potty because I like what they produce but they don't support their customers
    #43
    Thesame.man likes this.
  4. Arixto
    Cupcake Dec 1, 2019
    Arixto , Dec 1, 2019 :
    I have the same problem on my op7 pro,
    The microphone doesn't work well on speaker mode when calling
    #44
  5. Q1574380316118
    Cupcake Dec 3, 2019
    #45
  6. zp01
    Cupcake Jan 3, 2020
    #46
  7. SohMod123
    Donut Jan 6, 2020
    SohMod123 , via OnePlus 7 Pro , Jan 6, 2020 :
    they didn't help at all...an update fixed my phone, so I never went in, but you should send it to a OnePlus service store to help fix your phone if the updates don't help.
    #47
  8. Deactivated User
    Jan 6, 2020
    #48
  9. Thesame.man
    Cupcake Jan 8, 2020
    Thesame.man , Jan 8, 2020 :
    I have the same problen with my OP 6t ongoing 2 month. I've updated to Android 10, but the issue is not resolved.
    #49
  10. SohMod123
    Donut Jan 13, 2020
    SohMod123 , via OnePlus 7 Pro , Jan 13, 2020 :
    The best thing you can do as a temporary fix is to get some headphones so you can talk to people normally until they update the phone so it doesn't have an issue, or you take it to a OnePlus service center.
    #50
  11. diggyphil
    Donut Feb 11, 2020
    diggyphil , Feb 11, 2020 :
    I sent my OP7P in for repair because of the mic issue. On speaker, mine was fine. When using the headset mic(s) at the bottom of the phone was where the problem was occurring from. Using Google Assistant, from an unlocked state and using voice commands, worked perfectly and it heard and responded to everything. Activating Assistant manually somehow used the bottom mics. Assistant did not recognize my voice unless I was nearly screaming into the bottom mic on the phone. This was the same trying to use the recorder app on the phone - inaudible unless screaming into the bottom of the phone. Phone calls, from the headset, were garbled and seemed to cut out.
    Mine is on its way back, but they stated that the circuit board for mics 2 & 3 (who knew it actually had 3 mics) was faulty and had to be replaced - under warranty, of course. Crossing my fingers that fully resolved the issue.
    #51
    SohMod123 likes this.
  12. R1583590022738
    Cupcake Jul 13, 2020
    R1583590022738 , Jul 13, 2020 :
    This is the best reply your received for this problem: ONEPLUS DON'T CARE ABOUT YOU PROBLEM, only think in your money, my OP7PRO now have 8 months, in 3 months he shutdown entire mics, don't work right nothing, now is 5 months with oneplus bla bla bla, and nothing is maked, yes, you pay 800EU for phone have a stupid simple problem, I ASK FOR THEY WHAT MICROPHONE(PART) THIS JUNK USE, but they don't care about you problem (again) this is my first and last buy of this brand, i always continue to remember for anyways never buy another oneplus phone.
    Thank you!!
    #52
