Network/Connectivity Oneplus 7 Pro mobile data issue with Grameenphone
  1. primetunan
    Cupcake Jul 3, 2019
    primetunan , Jul 3, 2019 :
    Hi Good people,
    Sharing with you guys if someone from Bangladesh is facing any mobile data issue with OP7 Pro using Grameenphone connection. OS Version: Oxygen OS 9.5.8.GM21AA.
    Problem:
    Conditions: Data MB is available. Internet is turned on in SIM from Carrier.
    Mobile data sometimes connect perfectly. Other times, 4G or H+ sign comes & goes intermittently finally showing an exclamation mark around network signal. Only websites with domain "google.com" & some other limited apps work that time. Other internet things don't work at all. After rebooting or turning airplane mode on/off it solves but again comes back later.
    Solution:
    Go the Settings> Wi-Fi & Internet> SIM & Network> SIM 1 (Grameenphone)> Access Point Names
    Create a new APN with Name "GP-INTERNET", APN: "gpinternet". Click Save from the three dots on upper right side of screen. It will replace if any previous APN was there by default. Click on "GP-INTERNET" APN to see if APN Type field contains only "default" value. If any other value is there like the 1st screenshot, change it to "default" as like 2nd screenshot. Also change the "MVNO type" from "None" to "IMSI".
    Worked like a charm for me. 2 days with no problem & counting. Leave your thoughts in the comment
