OnePlus 7 Pro mobile data not working with lyca mobile in the UK
  1. G_Dibyendu_Paul_YcwF
    Eclair May 31, 2019
    G_Dibyendu_Paul_YcwF , May 31, 2019 :
    Hi Team,
    Could you please help.
    I am having lyca mobile 4G SIM which is working in OnePlus 5T. Also, If I insert India Vodafone 4G SIM it is also working perfectly. but the lyca mobile data is not working.
    I used the default settings which is there in uneditable format in APN SETTINGS.
    Unable to change or add anything there. Please any suggestions.
    Thanks
    Dibyendu
    W1559760477366 likes this.
  2. W1559760477366
    Cupcake Jun 5, 2019
  3. Cervantes
    Lollipop Moderator Jun 5, 2019
    Cervantes , Jun 5, 2019 :
    Hi
    You can create a new apn and configure the apn settings
  4. W1559760477366
    Cupcake Jun 5, 2019
  5. Cervantes
    it gives you some message
  6. W1559760477366
    Cupcake Jun 5, 2019
  7. Cervantes
    I created a test apn, name: pro, apn: pro, and I could save it
    You are configuring with the data of the telephone operator
  8. G_Dibyendu_Paul_YcwF
    Eclair Jun 5, 2019
    G_Dibyendu_Paul_YcwF , Jun 5, 2019 :
    Yes change the MVNO to IMSI.It will work. create a new APN.
  9. G_Viji_Laks_opzJ
    Cupcake Jun 6, 2019
    G_Viji_Laks_opzJ , Jun 6, 2019 :
    Hi,
    I have Lyca 4G sim in which mobile data is not working in Oneplus 7 pro.But in same mobile India airtel mobile data is perfectly fine.
    Unable to change or add anything there. Please let me know how to edit APN settings because new APN settings is not getting saved.
    Tried resetting network settings but still same issue.Could you please help with this issue?
  10. G_Viji_Laks_opzJ
    Cupcake Jun 6, 2019
  11. dyellacse
    Cupcake Jun 7, 2019
    dyellacse , Jun 7, 2019 :
    Hi Team,
    After adding new APN settings it's not getting saved.
    it's still pointing to old APN settings only, can you explain how to add new APN settings.
    Thanks,
    Yella.
  12. dyellacse
    Cupcake Jun 7, 2019
    hi can you explain how you added new APN settings
  13. KingCrushGroove
    Cupcake Jun 13, 2019
  14. Ahalya Natarajan
    Cupcake Jun 17, 2019
    Ahalya Natarajan , Jun 17, 2019 :
    Found the answer. While creating a new APN, set the "MVNO Type" at the bottom of the screen to "IVSI". It is usually not set to any value and Lyca's customer service people do not inform you about this setting.
    So, click on New APN
    Name: "Internet Lycamobile UK"
    APN: data.lycamobile.co.uk
    MVNO Type : IVSI
    then save the new APN. Internet should work.
  15. Ahalya Natarajan
    MVNO Type : IVSI
  16. G_Davan_Chike_IaZS
    Cupcake Jul 1, 2019
    G_Davan_Chike_IaZS , Jul 1, 2019 :
    Yes, this worked with mine. However the MVNO can only be selected and the right selection is IMSI. Voulla it should work
  17. Podaran
    Eclair Jul 3, 2019
    Podaran , Jul 3, 2019 :
    OMG, thanks so much guys, finally managed to get internet on my phone after struggling for a day! The MVNO-IMSI trick did it.
  18. W1571823364021
    Cupcake Oct 23, 2019
    W1571823364021 , Oct 23, 2019 :
    Hi,
    Update oxygen OS 10.0.1 , Mobile data not working for lycamobile UK , Its was working with MVNO set to IMSI. Now after update problem occurring again , anu clue ?
