Oneplus 7 Pro Navigation Bar Issue
  1. Naguya
    Cupcake Apr 21, 2021
    Naguya , Apr 21, 2021 :
    Greetings,
    kinda sad that my first own thread here is a support request but eh first time is first time right?
    To my problem. I've looked up for a solution and haven't found any suiting other then rebooting.
    My navigation bar goes unresponsive frequently since I updated to 11. I'm using the fixed buttons. My OnePlus is still useable even with a non-function nav bar. No lag or anything. I also should mention the "back" button still partially works. I'm unable to return to homescreen or go through open apps. I can spam the buttons but nothing happens. Holding still brings up Google Assist.
    Is there any solution that doesn't involve a factory reset? Am I missing something obvious?
    Best regards
    Update:
    Emptied cache and storage of the Launcher. not fixed yet
  2. Bobbie63
    Marshmallow Apr 21, 2021
    Best Answer
    Bobbie63 , Apr 21, 2021 :
    What if you delete the updates from the launcher?
    J4t1np4r3kh and Aaron2017 like this.
  3. NunoRMartins
  4. Aaron2017
    KitKat Apr 21, 2021
    Naguya, J4t1np4r3kh and Bobbie63 like this.
  5. Bobbie63
    I wanted to add if you also clear data of the launcher, you need to set up your homescreen again, so first just try to clear cache of the launcher app and reboot.
    btw this was your second post on the forums.:)
  6. Aaron2017
    KitKat Apr 21, 2021
    Aaron2017 , Apr 21, 2021 :
    Indeed, good save. I usually include that part, don't know why i forgot it this time tbh...
  7. Bobbie63
    You can’t remember always everything, that wouldn’t be healthy.;)
    Naguya, J4t1np4r3kh and Aaron2017 like this.
  8. Naguya
    Been there done that.
    You're right. I meant first thread and not post. I've corrected that. :)
    Too late hahaha...
    I've cleared the cache and the storage. It happened again. Anything else I can do? When I swap between navbar options its works for a short time again. I'll add what I've done to first post.
    J4t1np4r3kh, Aaron2017 and Bobbie63 like this.
  9. Naguya
    Seems that has done the trick. I'll wait for a bit if it reappears but so far it's gone. :)
    many thanks!
    Bobbie63 and Aaron2017 like this.
  10. Bobbie63
    Glad at least for now it worked, I hope it keeps on working.:)
    Naguya likes this.
  11. JulianLS
    Cupcake May 4, 2021
    JulianLS , May 4, 2021 :
    How to delete the launch update? Thanks!
  12. alek889 , via OnePlus 7 Pro T-Mobile , May 4, 2021 :
    Go to settings/Apps/See all apps.When U get here,hit the 3 dot menu in the top right and select "show system".Go all the way down in the list and look for "One Plus Launcher".Select the launcher and go to the 3dot menu in the top right and select "uninstall updates".Thats it!
