Oneplus 7 pro oxygen os downgrade via OnePlus 7 Pro
  1. ElGemy
    Cupcake May 7, 2021
    ElGemy , via OnePlus 7 Pro , May 7, 2021 :
    I've installed official oxygen os 11 and I'm facing heat issue and app close by itself I want to rollback to oxygen os 10 which I downloaded it when I do local upgrade it says that I can't go back to version lower than the current system.
    Anyone help me
  2. drl431
    Community Hero 2020 May 7, 2021
    drl431 , May 7, 2021 :
    Hi, the system will not allow the installation of an older OOS version than currently installed, so a rollback package has to be used. You can find one in the OOS 11 open beta 1 thread. But since the rollback package will wipe all data, you should try a factory reset. Back up your data (except the apps) to the cloud or a pc first.
  3. ElGemy
    Cupcake May 7, 2021
  4. drl431
    No, that's just the location of the rollback packages. But once you rollback, you may have to upgrade to the desired OOS10 version. Again, this will wipe all data.
  5. ElGemy
    Cupcake May 8, 2021
