3
OnePlus 7 Pro OxygenOS 10.0.1 update + keep TWRP & Magisk guide via OnePlus 7 Pro
  1. Dave1482
    Ice Cream Sandwich Oct 13, 2019
    Dave1482 , via OnePlus 7 Pro , Oct 13, 2019 :
    Since I have Visible, I have held off on updating to OxygenOS 10.0.0 (I have a GM1917 model on the GM21AA channel). Visible now works in OxygenOS 10.0.1.
    I have found a method for updating that works without needing a computer.
    What works:
    Root with Magisk 20.0
    TWRP installer zip (use only in TWRP) with unofficial 3.3.1-70
    Swift Installer theme engine
    Instructions for update if you're updating from Pie:
    I AM NOT RESPONSIBLE FOR BRICKING ANY DEVICE, THIS GUIDE IS JUST FOR THE OnePlus 7 Pro on International firmware (I'm on GM21AA). THIS SHOULD WORK WITH OTHER VARIANTS BUT I CANNOT GUARANTEE ANYTHING! USE AT YOUR OWN RISK!
    PREREQUISITES
    • TWRP is preferred to be already installed
    • Prior rooting preferred
    • You must download above files
    • You must download the full ~2 GB OTA
    • Also have the Magisk uninstaller in case things get messed up
    Steps Part 1
    If you already have TWRP skip to "Steps Part 2"
    1. If your bootloader is already unlocked skip to step 5
    2. Download TWRP .img to your computer
    3. Install OnePlus adb and fastboot drivers on your computer
    4. Run "fastboot oem unlock" without quotes
    5. Flash TWRP .img file from computer to slot A with "fastboot flash boot_a path-to-twrp.img"
    6. Flash TWRP .img file from computer to slot B with "fastboot flash boot_b path-to-twrp.img"
    7. Run "fastboot reboot recovery"
    8. If your OTA is on your computer, copy it to /sdcard/ on your OnePlus 7 Pro
    Steps Part 2
    1. flash full OTA VIA TWRP, DO NOT USE SETTINGS APP
    2. flash TWRP installer 3.3.1-70 zip via TWRP
    3. Flash Magisk 20.0
    4. Switch active boot partition
    5. Reboot to TWRP recovery
    6. install Magisk again
    7. reboot to system
    IF THERE ARE ISSUES WITH NO SIM CARD SHOWING OR NO CELLULAR CONNECTION
    1. Download the Magisk uninstaller above
    2. Reboot to TWRP
    3. Flash Magisk uninstaller
    4. Reflash Magisk 20.0
    5. Reboot to system
  2. Dave1482
    Ice Cream Sandwich Oct 14, 2019
  3. Dave1482
    Dave1482 , Oct 14, 2019 :
    For those of you who are using different devices, the process MAY be similar but I am not 100% sure. If you want to risk it, you can try it.
    Georgeoneplus7pro likes this.
  4. RandomDude66613
    Gingerbread Oct 14, 2019
  5. Dave1482
    Ice Cream Sandwich Oct 15, 2019
    Dave1482 , Oct 15, 2019 :
    The OnePlus 7 Pro has a Slot A and a Slot B. If you're in TWRP, it shows the current slot when you press the Reboot button on the home page. When you're there, press the Slot you are not currently on and it will switch the active boot partition on your next boot.
  6. LeTronique
    Cupcake Oct 18, 2019
    LeTronique , Oct 18, 2019 :
    What if I don't have TWRP installed? How do I boot from it because when I do, I get stuck at the "OnePlus Logo Fastboot Mode" page. My BL is unlocked, phone is unlocked but I can't root it because I don't have TWRP.
  7. Khaledmayas
    Cupcake Oct 21, 2019
    Khaledmayas , Oct 21, 2019 :
    I've unlocked my op7pro then I tried to install TWRP but it fail and the phone just stuck on the black screen with fastboot mode on it i manage to restart it and try to do that again with different TWRP but it will do the same. any help how to install the TWRP?? Android 10 Build Number OP7PRO_02_BETA_3
  8. Dave1482
    Ice Cream Sandwich Oct 25, 2019
    Dave1482 , Oct 25, 2019 :
    You just download the TWRP 65 IMG file from here then push this file to /sdcard/ then flash it to install TWRP
  9. Dave1482
    (I might have to update the guide to include instructions on how to install TWRP in the first place
  10. Dave1482
    You need TWRP 65 or 70 (I recommend 70)
  11. Khaledmayas
    Cupcake Oct 30, 2019
    Khaledmayas , Oct 30, 2019 :
    Hi, I've tried all the instruction step by step and it works TWRP installed but once I flash the Magisk no sim card showing and no signal and I did the instruction you give about that but it didn't work. any idea? and now I've update it to BETA 4
    Dave1482 likes this.
  12. Dave1482
    Ice Cream Sandwich Oct 30, 2019
    Dave1482 , via OnePlus 7 Pro , Oct 30, 2019 :
    Khaledmayas
    Hi, I've tried all the instruction step by step and it works TWRP installed but once I flash the Magisk no sim card showing and no signal and I did the instruction you give about that but it didn't work. any idea? and now I've update it to BETA 4​
    run Magisk uninstaller then reinstall Magisk 20.0. I used the Uninstaller zip
  13. Khaledmayas
    I've did that too
  14. Dave1482
    maybe clear cache, uninstall Magisk zip, then boot without Magisk, see if it works, then go back to TWRP and flash magisk
  15. Khaledmayas
    Ok I'll give that a try and I'll keep you updated. Thanks.
  16. Dave1482
  17. Khaledmayas
  18. Khaledmayas
    Khaledmayas , via OnePlus 7 Pro , Oct 30, 2019 :
    Hi, I have one more question. you mentioned that after flashing the TWRP we need to switch so when I got there the slot was on A so I switch to B but when I rebooted it stuck on the two dots rotating around the circle.
  19. G1572592589809
    Cupcake Nov 1, 2019
    G1572592589809 , Nov 1, 2019 :
    Hi! i have your same issue, did you sort it out anyhow?
  20. Khaledmayas
    Cupcake Nov 1, 2019
