OnePlus 7 pro screen issues
  1. cdash332 Froyo May 22, 2019
    cdash332, May 22, 2019 :
    I am facing below issues on my op7 pro
    1. While in call if i drag down, notification menu is not coming down properly i have to drag from top to bottom to bring it down.
    2. Some times launched is stop responding, it will take some 20-30 sec to give the error message and after stopping the launcher it starts work properly.
    if anyone is having these issue pls tell if you found any solution for these.
  2. OnePlus_Robot Cupcake May 22, 2019
    OnePlus_Robot, May 22, 2019 :
    I dont see such issues on my phone.
    Are you using some touch wizard or screen assist?
    Disable that & try again
  3. cdash332 Froyo May 22, 2019
    not using anything, on stock i am facing these
  4. Gav_W86 Starting Point Expert May 22, 2019
    Gav_W86, May 22, 2019 :
    1. I think it is by design in a call, it has been an 'issue' for a while with previous devices too.
    2. try: settings > apps & notifications > oneplus launcher > storage > clear cache (don't clear storage it will reset your launcher to default layout/options) > reboot
    buntycubal likes this.
