OnePlus 7 Pro Warp Charging Slow
  1. Ale130799
    Cupcake Aug 7, 2019
    Ale130799 , Aug 7, 2019 :
    Guys, why my OP7Pro charging (with warp charge and box cable) is "very slow" than the promise of OnePlus? I've already checked in different cases, and these is the results
    dcklingel likes this.
  2. Swejuggalo
    Jelly Bean Aug 8, 2019
    Swejuggalo , Aug 8, 2019 :
    Were is the promise of 1h for 100%?
    I heard some reviewers say it but I never seen it written in some official text. Only pretty vage texts on official sources as far as I have found.
    I have around 80 minutes and consider that to be pretty normal under most circumstances. High or low temperatures affect it.
    slufoot69 likes this.
  3. Swejuggalo
    After all a full discharge is not recommended to do on regular basis anyway. Depending on sources you should try to keep it within 50-90% and only do full discharges limited times.
    CosminMaier likes this.
  4. upendrarabina
    Cupcake Aug 23, 2019
    upendrarabina , Aug 23, 2019 :
    i have started charging my oneplus 7pro from 15% & it charged 100% at 93mins . . . .. why so slow ?
  5. Swejuggalo
    Jelly Bean Aug 23, 2019
    Swejuggalo , Aug 23, 2019 :
    Most limiting factor is temperature of battery. If the phone is abit warm before starting a charge that could add some extra time. The biggest charge boost compared to Dash is in the early parts of the charge. The higher up the gap shrinks.
    Without knowing details on how your charges looks its hard to know why your charge is 10 minutes longer than mine. My full charge was done without a case on with small usage during charge with pretty normal low temperatures.
  6. slufoot69
    Donut Aug 23, 2019
  7. Swejuggalo
  8. slufoot69
    Donut Aug 23, 2019
    slufoot69 , Aug 23, 2019 :
    Is there a premium version? Have to get rid of the adds. Cannot find it in settings.
  9. Swejuggalo
    Does not look like it. It is that kind of app you use for a charge or 2 and then trow it away when you know how your phone behaves.
  10. Swejuggalo
    I have some other tip if you want to know details about consumption though. Betterbatterystats.
  11. slufoot69
    Donut Aug 23, 2019
    I use Accubattery but I just liked the graphical representation of charge and discharge.
  12. Swejuggalo
    Yeah. It was the best way to show a charge cycle that I could find.
    I use BetterBatteryStats to get a good idea of all the wakelocks. Adb gives the possibilities to disable app wakelocks [e]1f60a[/e]
  13. G_android_x14
    Gingerbread Aug 23, 2019
    G_android_x14 , Aug 23, 2019 :
    Actually the other limiting factor, that is greater then temperature is "what else is using battery" - unless you charge with the phone powered off, the CPU is running, apps are running in the background, cell radio(s) are talking to towers, wifi, bluetooth, and sensors may be on.
    For anyone complaing about a 90 minute charge. Go old school and plug the phone into your PC - 5V - 500ma - see how long that takes and then report back. 5-6 hours is my guess. Then plug into a more modern charger that puts out 1 amp and you will be down to about 3 hours, maybe.
    Also, make sure all your charging tests have the phone powered 100% off to make sure nothing is using battery while charging it. Then report back.
  14. Jigs218
    Cupcake Aug 24, 2019
    Jigs218 , Aug 24, 2019 :
    My phone is not charging at WRAP Speed.its charging at normal speed. on status bar it's showing normal charging icon instead of Lighting I on.
    please help.
  15. slufoot69
    Donut Aug 24, 2019
    slufoot69 , Aug 24, 2019 :
    I assume your using the stock charger and cord? if so I'd say something wrong with charge port or charge adapter or cable. sorry not much help
  16. upendrarabina
    upendrarabina , Aug 24, 2019 :
    today i drained my oneplus 7pro to 0% and started charging without case in turned off mode . . . . . .it took 1hr 43min to 100% why is my phone taking longer than others . . . . i m using ginune warp charger .
  17. G_android_x14
    Gingerbread Aug 24, 2019
    G_android_x14 , Aug 24, 2019 :
    sounds normal to me. but what was battery temp, how many cycles has it been through. need that data to compare.
    what did you expect?
  18. Jigs218
    Resolved only after resetting the device.
    but sure there is a bug in this firmware.
  19. slufoot69
    Donut Aug 24, 2019
    I would recommend a factory reset and install after Q comes out. Just back everything up with OnePlus switch on play store. This is just a recommendation.
  20. upendrarabina
    Cupcake Aug 25, 2019
    upendrarabina , Aug 25, 2019 :
    i was looking for around 1hr 20 or 30 min since its 30wat charger. charge cycle i dont know but its new charger 5 6 times till now .
