Working OnePlus 7 pro water proofing via OnePlus 7 Pro
  1. Jalil.Irfan
    Froyo Sep 9, 2020
    Jalil.Irfan , via OnePlus 7 Pro , Sep 9, 2020 :
    Hi guys,
    I accidently punched in the microphone hole on top with the aim ejector tool instead of punching at the sim tray at the bottom of the phone.
    Will it make any issue with the existing water proof layering?
    Secondly can I do nano coating where the coating is spayed in to the mobile will it cause any issue to mobile?
  2. Gav_W86
    Starting Point Expert Community Expert Sep 9, 2020
    Gav_W86 , Sep 9, 2020 :
    depends on how badly you inserted the tool.
    re nano coating - opening the phone to apply internally will void the warranty. if not applied properly anywhere it can cause issues with the phone. but in theory if done perfectly they work pretty well
    Artemus. and Jalil_Irfan_M_U like this.
  3. Jalil.Irfan
    Froyo Sep 9, 2020
    Thanks for the info.
    But the phone will not be opened at all.
    As per the promotions it will be kept in a special device which will spray the nano coating in one end and the other end sucks it so the coating is applied without opening the mobile
  4. Gav_W86
    not heard of that one. not sure that will work, would likely just clog in the existing waterproofing. Also not sure how they would ensure how it coats the insides properly/evenly in that way.
    Jalil_Irfan_M_U likes this.
  5. Jalil.Irfan
    Froyo Sep 10, 2020
    Jalil.Irfan , via OnePlus 7 Pro , Sep 10, 2020 :
    Ya same doubts
