Working
oneplus 7 pro wrap charging not working
  1. J1559236617343 Cupcake Aug 14, 2019 at 8:59 AM
    J1559236617343, Aug 14, 2019 at 8:59 AM :
    Dear Team,
    good day,
    from last few days i have noticed that my mobile battery is getting drained so fast and it takes too much time to charge while checking the screen it seem like it is in normal mode charging as previously while charging the screen was displying wrap charging symbol.
    please help me to rectify
    regards,
    Nithin.
  2. Gav_W86 Starting Point Expert Aug 14, 2019 at 1:24 PM
    Gav_W86, Aug 14, 2019 at 1:24 PM :
    re battery use:
    battery use depends mostly on your use, what apps you have installed, and what settings/services are running.
    what do the battery use screens in settings say is using your battery?
    best to look after a full (100% to <10%) single charge use for best info.
    you can post screenshots (both the 1st screen that says screen on time and the app use screen) here if you need assistance interpreting.
    re: charging:
    is it using the original OnePlus Warp charger and cable?
    are the charger, cable and socket clean, clear and undamaged?
    is the power socket providing full power?
    Is it hot and humid there?
    J1559236617343 likes this.
  3. J1559236617343 Cupcake Aug 14, 2019 at 3:39 PM
    J1559236617343, Aug 14, 2019 at 3:39 PM :
    i am using a 4months old mobile. i am using original cable and charges. i fell the difference after updating the last os update and i had charged the mobile while traveling in train in train power socket
  4. Gav_W86 Starting Point Expert Aug 15, 2019 at 1:22 PM
    Gav_W86, Aug 15, 2019 at 1:22 PM :
    train power sockets often don't produce a stable full power supply (they only have a limited available voltage and the more people on the train use it the less stable it gets). does it work on a reliable fixed mains power supply?
