2
Oneplus 7 - PUBG PROBLEM
  1. G_Man_Wayne_AKfW
    Donut Jul 21, 2019
    G_Man_Wayne_AKfW , Jul 21, 2019 :
    when i play PUBG sometime button fire not respon and
    mine looks up to the sky automatically, since i bought it ive had the same issue updates didnt fix it.
    @Abhishek1 and gumminis like this.
  2. Neddard
    Lollipop Jul 21, 2019
    Neddard , Jul 21, 2019 :
    What does PUBG tech support suggest?
    G_Man_Wayne_AKfW likes this.
  3. G_Man_Wayne_AKfW
    Donut Jul 21, 2019
  4. Neddard
    Right.
    PUBG devs should fix their junky app.
  5. G_Man_Wayne_AKfW
    Donut Jul 21, 2019
    i post in group fb not only me got this problem..
  6. Neddard
    Even more reason for PUBG devs to clean up their junk.
  7. P1563561949654
    Cupcake Jul 21, 2019
    P1563561949654 , Jul 21, 2019 :
    pubg developers can better support on this as OnePlus developers did a great job on touch and everything.
    I hope your problem get solved soon.
  8. O1566402236465
    Cupcake Aug 21, 2019
    O1566402236465 , Aug 21, 2019 :
    i am a claw player and facing the same issue... now confused, the issue with one plus or pubg hope it will be fixed soon
    I1566520393750 likes this.
  9. TVTV
    Gingerbread Aug 21, 2019
    ascent likes this.
  10. ascent
    Honeycomb Aug 22, 2019
    ascent , Aug 22, 2019 :
    Do you play with the phone in the supplied TPU case? And if not, could you try if this helps? This is related to the thread @TVTV mentioned
  11. I1566520393750
    Cupcake Aug 23, 2019
    I1566520393750 , Aug 23, 2019 :
    me and one of my friend hav the oneplus 6 and we both facing the same problem did u get the solution?
  12. O1566402236465
    O1566402236465 , Aug 23, 2019 :
    yes I am using the same case which provided with the box.
  13. I1566520393750
    but bro my phone is 1yr old now and i dnt hv the tpu case which provided with the box i hv oneplus 6
  14. O1566402236465
  15. @Abhishek1
  16. Amit_Ingti_Kathar
    Froyo Aug 27, 2019
    Amit_Ingti_Kathar , Aug 27, 2019 :
    I am facing the same problem. Oxygen 9.5.8 didn't fix the problem. It's very annoying. I bought OP7 on 25th, Aug, I bought this phone specially for PUBG. If this won't fix early I have to opt to a device that don't have this problem
    San Shotz and O1566402236465 like this.
