17
[OnePlus 7][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. cruskhad
    Cupcake Jun 8, 2019
    cruskhad , Jun 8, 2019 :
    My bad, my bad. Strangely enough, my OnePlus 5T market has Google Play, but OnePlus 7 doesn't. They removed Play Store on purpose.
  2. Anchun7692
    Donut Jun 8, 2019
    Anchun7692 , Jun 8, 2019 :
    Funnily enough you do find quite a lot of Google apps on there such as Google photos, Google play movies, Google maps... but without getting the correct framework packages first (play services, authentication service...), impossible to sign in so pretty useless.
  3. cruskhad
    Cupcake Jun 8, 2019
    however I think it's pretty easy to find google play market apk on the internet.
  4. Titokhan
    Honeycomb Jun 8, 2019
    cruskhad likes this.
  5. Titokhan
  6. cruskhad
    Cupcake Jun 8, 2019
    Titokhan likes this.
  7. Anchun7692
    Donut Jun 8, 2019
    Thanks Titokhan, yes that was my plan, I did unlock bootloader and fastboot is working fine but I cannot find the ROM for hydrogen OS 9.5.2 anywhere, otherwise would downgrade and then install any of the two OxygenOS ROMs via local update.
  8. mudassarrauf
    Froyo Jun 8, 2019
    mudassarrauf , Jun 8, 2019 :
    just clear cache of google play and restart the phone ...
  9. mudassarrauf
    Froyo Jun 8, 2019
    just install the google play store apk only ... i works for me as hydrogen os already has google services preinstalled
  10. machetazomx
    Eclair Jun 8, 2019
    machetazomx , Jun 8, 2019 :
    Hello, one question
    I have OP7 Pro Chinese version (GM1910) with 9.5.5.GM21BA(EU) Firmware.
    This version 9.5.5.GM21BA can be upgraded to 9.5.7GM21AA without problems in local update with the zip file?
    Thank you
  11. cruskhad
    Cupcake Jun 8, 2019
    Hello! This thread is for OnePlus 7, not 7 Pro.
  12. Anchun7692
    Donut Jun 9, 2019
    Anchun7692 , Jun 9, 2019 :
    Which version of play store did you install ? Tried to clear cache and restart, still can't sign in. (VPN on of course)
    mudassarrauf likes this.
  13. Anchun7692
    Donut Jun 9, 2019
    OK I did manage to "upgrade" from Hydrogen OS 9.5.4 to Oxygen OS 9.5.4 but this is a bit convoluted so would not recommend, probably better to wait for official OxygenOS ROM if you made the mistake to upgrade stock HydrogenOS
    1) Install Android Q update, from local update.
    https://oxygenos.oneplus.net/OnePlu...l_1905191801_fullupgrade_c7f1193579a84919.zip
    The annoying part, when rebooting and set up
    NB The phone wants to contact google server, so if you are in Mainland China you need connect to a WIFI network with VPN activated on it, worth remembering otherwise you will get stuck
    2) Install Oxygen OS ROM from this thread
    After reboot, I ended up in recovery mode, not sure why. Wiped everything, reboot and it worked.
    Set up again.
    Abdel_005 likes this.
  14. Emory
    Cupcake Jun 9, 2019
    Emory , Jun 9, 2019 :
    Thanks ! Well, I did not know the Google services werer already installed... I tried to install all the package manually before. So, I just installed the Play Store apk and it worked. But I face the same problem as Anchun : I can't sign in despite clearing the cache, the data and rebooting the phone several times. Of course I use a vpn
  15. Emory
    Cupcake Jun 9, 2019
    You installed the global ROM from Hydrogen? How did you do?
  16. mudassarrauf
    Froyo Jun 9, 2019
    mudassarrauf , Jun 9, 2019 :
    give it time ... for first time it took very long for sign in page to appear ... I think about 5 min ...
  17. mudassarrauf
    Froyo Jun 9, 2019
    give it time about 5 min ... no need for VPN if you are not in China
  18. mudassarrauf
    Froyo Jun 9, 2019
    I was using xiaomi mi 8 ... I just transfer that apk to this op7 ... it took about 5 min for sign in page to appear
    #38
  19. Emory
    Cupcake Jun 9, 2019
    Actually for me the problem is that after 1 minute of "Checking info", the message changes to "Couldn't sign in; THere was a problem communicating with Google servers". I guess I will wait until the global ROM is released to use my OP7
    #39
  20. cruskhad
    Cupcake Jun 9, 2019
    cruskhad , Jun 9, 2019 :
    I mean I bought OnePlus 7 in China with Hydrogen. I didn't update Hydrogen OS, this is very important. Then just copied Oxygen OS Global to the root folder of the phone, then Local Upgrade. As Oxygen is a newer version than Hydrogen on my phone, it was easy. After phone restarted, I wiped all the data from the Settings.
    #40
