11
[OnePlus 7][ROM][OTA][Oxygen OS] Repo of Oxygen OS Builds
  1. mudassarrauf Froyo Jun 9, 2019
    mudassarrauf, Jun 9, 2019 :
    where did you download global os ?
    #41
  2. cruskhad Cupcake Jun 9, 2019
    cruskhad, Jun 9, 2019 :
    from this thread, isn't one Global and another one European?
    #42
  3. Michael Hui Donut Jun 10, 2019
    Michael Hui, Jun 10, 2019 :
    In your last part, how to wipe all data from the Settings? Where can I locate the option? Does it mean wiping all the previous Hydrogen Chinese ROM data?
    #43
  4. cruskhad Cupcake Jun 10, 2019
    cruskhad, Jun 10, 2019 :
    I think you lose Hydrogen OS when you do local upgrade to Oxygen OS. re you questions: settings - system - reset options - erase all data. I did it because some people recommended it.
    #44
    Michael Hui likes this.
  5. Michael Hui Donut Jun 10, 2019
    Thanks! just switched to international ROM in mins :)
    #45
    cruskhad and mudassarrauf like this.
  6. mudassarrauf Froyo Jun 10, 2019
    mudassarrauf, Jun 10, 2019 :
    do we have to wipe the data after that or it's ok to not wipe it ??
    #46
  7. Michael Hui Donut Jun 10, 2019
    I do suggest swipe the old data to keep the ROM clean which helps performance a bit
    #47
    mudassarrauf likes this.
  8. Emory Cupcake Jun 11, 2019
    Emory, Jun 11, 2019 :
    Do you remember which Hydrogen OS version you had before the switch? Mine is 9.5.4, therefore I can't upgrade to the Global ROM 9.5.4 as the phone "can't be downgraded"...
    #48
  9. Michael Hui Donut Jun 11, 2019
    Michael Hui, Jun 11, 2019 :
    Mine was 9.5.2, should not be upgraded to 9.5.4 Hydrogen ROM as the system would treat it as the latest version and forbidden the switching to International 9.5.4 Oxygen ROM.
    #49
    cruskhad likes this.
  10. mudassarrauf Froyo Jun 11, 2019
    mudassarrauf, Jun 11, 2019 :
    can we use local backup option to restore after wipe ??
    #50
  11. Michael Hui Donut Jun 11, 2019
    I did not try it but suppose the old data has been wiped and cannot be restored to the previous version.
    #51
  12. Emory Cupcake Jun 11, 2019
    Thanks for the feedback. Mine was the 9.5.4 as stock. So I guess I just have to wait for the next global ROM update
    #52
  13. Anchun7692 Donut Jun 11, 2019
    Anchun7692, Jun 11, 2019 :
    Emory I had the same issue .You can check how I solved it by upgrading to Android q beta I posted this before in the same thread. I'm not saying it's a great method but it worked for me
    Post 33
    https://forums.oneplus.com/threads/...oxygen-os-builds.1048241/page-2#post-20401018
    #53
  14. Emory Cupcake Jun 12, 2019
    Emory, Jun 12, 2019 :
    I followed your advice and it worked very well. It's actually very easy. Thanks a lot ! I'm in China but I did not have a problem with the system asking to connect to the internet. I just skipped it and then installed Oxygen OS. Happy to use my OP7 now with EU rom!
    #54
  15. Anchun7692 Donut Jun 12, 2019
    Anchun7692, Jun 12, 2019 :
    Glad I could help.
    #55
  16. Titokhan Honeycomb Jun 16, 2019
    #56
    chriskwarren2 and mudassarrauf like this.
  17. rwmchan Jelly Bean Jun 17, 2019
    rwmchan, Jun 17, 2019 :
    thanks for your update :D
    #57
    Titokhan likes this.
  18. weedee Gingerbread Jun 18, 2019
    weedee, Jun 18, 2019 :
    This is quite nice, but what will happen to the Widevine Level when flashing Global or EU OOS on top of Chinese HOS?
    //edit: You check this with "DRM INFO" app, thank you.
    #58
  19. Titokhan Honeycomb Jun 27, 2019
    #59
  20. 千叶の堕天圣黑猫“ Cupcake Jun 27, 2019
    #60
