12
Oneplus 7 touch issues
  1. Loveit
    Jelly Bean Jul 29, 2019
    Loveit , Jul 29, 2019 :
    You mean the double tap to wake would be being activated?
  2. Baymax
    Starting Point Expert Jul 29, 2019
    Baymax , Jul 29, 2019 :
    Yeah.
    Same sort of thing happened with 7 Pro.
    OnePlus figured out it was software and it ended up fixing the device after a couple of updates.
    eduardeutsch and Loveit like this.
  3. Loveit
    Oh dang I thought this was talking about Pro..
    Yeah you could be right, I was really just weighing up the odds in my head and it kind of felt like a hardware issue...
    Baymax likes this.
  4. TVTV
    Gingerbread Jul 29, 2019
    TVTV , Jul 29, 2019 :
    Could be a software issue still, because for me it happens intermittently. Could just be that they have turned the screen sensitivity up a lot in order to allow for a good experience for people with tempered glass. Let's wait and see if they fix it. If not, return and change brand, sadly...
    eduardeutsch likes this.
  5. Baymax
    best thing you can do is report directly to OnePlus
    TVTV and eduardeutsch like this.
  6. eduardeutsch
    Eclair Jul 29, 2019
  7. TVTV
    I could, but since a bug hunter is already on this and the guys have created a feedback thread too, I thought I wouldn't fill the forum with duplicate threads. :)
    Alex
    Baymax likes this.
  8. Baymax
    my bad bud xD
    but others should submit reports too. the squeaky wheel gets the grease after all
  9. TVTV
    Fair enough! :)
    I have just taken a more detailed video of the issue. Watch the pinkie!
    I will submit a new report tomorrow.
    Alex
  10. eduardeutsch
    Eclair Jul 29, 2019
    eduardeutsch , Jul 29, 2019 :
    Exact the same here!
    G_Andreas_Glatz_YMJL and TVTV like this.
  11. G_Andreas_Glatz_YMJL
    Froyo Jul 30, 2019
    G_Andreas_Glatz_YMJL , Jul 30, 2019 :
    can confirm that too
    TVTV likes this.
  12. TVTV
    Gingerbread Jul 30, 2019
    TVTV , Jul 30, 2019 :
    For me it is apparently getting worse. It used to happen intermittently before, but now it happens 80% of the time. I have switched to using the stock transparent case so I can still use the phone with one hand.
    For the record, I have tried everything: factory reset, NFC on or off, mobile data off, WiFi off, nothing helps but airplane mode. Clearly, this is somehow related to the radios, but in the moments when the phone is fine it will work even when downloading stuff over WiFi or mobile data. Weird.
    Can you guys try one thing for me, please? Can you switch your phones to airplane mode when you see the random touch thing happening? Do things go back to normal in airplane mode for you, too?
    Thanks,
    Alex
  13. G_Andreas_Glatz_YMJL
    Froyo Jul 30, 2019
  14. eduardeutsch
    Eclair Jul 30, 2019
    eduardeutsch , Jul 30, 2019 :
    Yes, can confirm that too. No issues while on airplane mode!
    TVTV likes this.
  15. TVTV
    Thanks, guys!
    Clearly something related to radio, then.
    It is a bit weird that only a few people are reporting this issue. Hope OP prioritizes a fix for the next software update...
    Alex
  16. G_Andreas_Glatz_YMJL
    Froyo Jul 30, 2019
    lars.stokholm and eduardeutsch like this.
  17. eduardeutsch
    Eclair Jul 30, 2019
    In my experience: two devices, both with the same issue.
    Two options:
    1- all OP7 are faulty
    2- ..or maybe a software issue for all
  18. TVTV
    Eduard, it is a shame that you didn't hold on to 9.5.3 on the second device a while longer for further testing. Saying this since the bug comes and goes so if you've updated right away then we can't know for sure that it wasn't there in an older version.
    Alex
    #38
  19. eduardeutsch
    Eclair Jul 30, 2019
    I thought it was an HW issue so decided to upgrade. I've tested for one hour or so, different times. Then upgraded.
    #39
    TVTV likes this.
  20. ascent
    Honeycomb Aug 1, 2019
    #40
