OnePlus 7. USB problems.
  1. DianaM
    Cupcake Jun 3, 2020
    DianaM , Jun 3, 2020 :
    Hi everyone. I'm from Spain and I have Oxygen OS 10.3.2. GM57AA. I don't know since when I have this version, 'cause I've automatically updates on.
    I connected my OP7 to my computer a few weeks ago, without any problem. But today, when I try to connect it, it does nothing. It doesn't display usb menu (at the notificacions' bar), so my pc can't recognize it. The phone only charges.
    I tried changing the usb options, from the settings menu, I enabled file tranfers, and USB debugging (I don't really know its name in English, sorry: the ADB options is on).
    Nothing works. Neither rebooting, nor turning off all...
    What can I do?
    Sorry, but I can't speak/write in English very well.
    Thanks.
    Edit: That's really weird. I turned off both, Pc and phone. I turned all on without any change. I turned on ubication and then I heard the sounds in both. There's no problem now.
    I will let this comment if can help anyone with the same issue.
    Artemus. likes this.
  2. ivanogarev
    Cupcake Jun 7, 2020
    ivanogarev , via OnePlus 8 , Jun 7, 2020 :
    Tengo exactamente el mismo problema con el OnePlus 8. De momento no me han dado ninguna solución, solo que pruebe distintos cables y como es lógico sin resultado. Les he enviado las grabaciones de pantalla y el informe de liga, pero sigo esperando solución. ¡Suerte, y a ver si lo solucionamos!
