OnePlus 7 wifi issue
  1. g_ngan
    Gingerbread Aug 27, 2019
    g_ngan , Aug 27, 2019 :
    My 7 is acting up lately.
    it keeps trying to search for wifi but cannot see anything. Other phones are seeing and connecting to wifi.
    Restarting does the trick but what's wrong?
  2. Swejuggalo
    KitKat Aug 31, 2019
    Swejuggalo , Aug 31, 2019 :
    Seems like some kind of driver failure. Tried to send in a bug rapport when having the issue with the built-in feedback tool of the community app?
  3. Shaquil_khan
    Cupcake Sep 3, 2019
    Shaquil_khan , Sep 3, 2019 :
    having same issue even if connected its stop receiving data first I thought that is WiFi issue but it's OnePlus 7 issue coz OnePlus 5 working fine in same wifi
  4. cruzAD
    Gingerbread Sep 11, 2019
    cruzAD , Sep 11, 2019 :
    I have az also strange wifi issues. I have a 6T and the 7. The 6T is connecting normally. But the 7 need much more time to connect to the wifi, and first it says there is no internet connection, after a few seconds it reconnecting and finding the connection. And when I'm on the Wifi with the 7 the Oneplus community app and Tapatalk says there is no internet connection, network error. And if I test the connection with Speedtest.net,it shows as no problem with the connection at all, but if I test the connection with Meteor, it shows strange connection problem. It couldnt start the downloading, even the ping test, usually have to wait long seconds, finally it measures the ping, what is a normal value, 15-20 something, as if there was no problem, again seconds waiting, and finally starts the downloading, what is seems normal in speed. So there is long seconds at least 5-10s waiting without connection, when the measurment can finally starts. And I cant use the Oneplus community app and Tapatalk in Wifi with the 7 because it says network problem and no connection. Connection Error and Network error (get_config). Problems are not permanent but occur. And with the 6T there is no problem.
  5. Skawty2hawty
    Cupcake Sep 12, 2019
    Skawty2hawty , Sep 12, 2019 :
    Did you really say "rapport"? I'm assuming you meant RE-port.[e]1f61c[/e]
  6. Swejuggalo
    KitKat Sep 12, 2019
    Swejuggalo , Sep 12, 2019 :
    Some Swedish spelling sneaking in [e]1f609[/e]
