Oneplus 7pro OTG is not detecting my pendrive but same pendrive work with my OP5t
  1. neilhingu Froyo May 21, 2019
    neilhingu, May 21, 2019 :
    Hi Everyone,
    Recently I have tried connecting my pendrive using OTG cable its not detecting but same set of OTG cable with pendrive is working with my OP5t anyone facing same issue.
  2. stark2991_PL KitKat May 21, 2019
    stark2991_PL, May 21, 2019 :
    It sometimes happens that particular device is just not compatible with the particular phone.
    Check your 7 Pro with another pendrives and you'll have the answer.
  3. Sridhar Ananthanarayanan Lollipop May 21, 2019
    Sridhar Ananthanarayanan, May 21, 2019 :
    Try enabling the otg button under settings.
  4. neilhingu Froyo May 21, 2019
    yes I did that also.
