OnePlus 7pro punch hole like 8 pro issues via OnePlus 7 Pro
  1. IBOCHOUBA
    Cupcake Jul 3, 2020
  2. R.Peter
    Honeycomb Jul 3, 2020
    R.Peter , Jul 3, 2020 :
    What OS do you use? And what apps did you install recently that can generate such a hole? I also use a 7 pro and I don't have such a thing.
    ykrudra likes this.
  3. IBOCHOUBA
    Cupcake Jul 3, 2020
    IBOCHOUBA , via OnePlus 7 Pro , Jul 3, 2020 :
    I am using latest os attached screen shot.
  4. R.Peter
    Then check which apps capable of modifying the notification area, if you have a notch-designer app, for example.
    Bouncer71 likes this.
  5. dsmonteiro
    Community Consultant Staff Member Jul 3, 2020
    dsmonteiro , Jul 3, 2020 :
    Have you checked your notifications to check if that isn't a notification logo?
    Artemus. and Bouncer71 like this.
