20
Oneplus 7pro warp charge not working
  1. LeelaPakanati
    Donut Jun 7, 2019
    LeelaPakanati , Jun 7, 2019 :
    My one plus 7 pro does not warp charge. I am using the original cable and block and it just charges regularly, that too rather slowly: ~1400mAh as read using Ampere app.
  2. S1543443828683
    Cupcake Jun 8, 2019
    S1543443828683 , Jun 8, 2019 :
    I also have the same problem. Warp charge is not working. I am in South Africa. My phone was ordered from the US.
    lirannl, Menahjatwa and Zvoni like this.
  3. Michael S. Nielsen
    Eclair Jun 8, 2019
    Menahjatwa likes this.
  4. OPOBEAST
    Honeycomb Jun 8, 2019
  5. Michael S. Nielsen
    Eclair Jun 8, 2019
  6. OPOBEAST
  7. Michael S. Nielsen
    Eclair Jun 8, 2019
  8. OPOBEAST
    OPOBEAST , Jun 8, 2019 :
    Hm should be fine then... Try contacting the OnePlus Support about the issue. Maybe you have a faulty Charger/Smartphone.
    Deactivated User likes this.
  9. MattBoxer
    Gingerbread Jun 8, 2019
    MattBoxer , Jun 8, 2019 :
    I seem to be having this issue to after 9.5.7, my device keeps switching between warp charge and normal charging about every 4-5 seconds.
    Hargovind.2.3 and Menahjatwa like this.
  10. Michael S. Nielsen
    Eclair Jun 8, 2019
    Menahjatwa and MattBoxer like this.
  11. MattBoxer
    @Bobby D. Can I send you a log file as well as screen shot and video recording of the problem?
  12. MattBoxer
    Update: after the phone reached 90% it stays on warp charge and doesn't change back unlike it was, to make sure I discharged my phone and it started the same behaviour again (changing between warp and standard), then above 90% again it was back to normal. This is strange.
  13. LeelaPakanati
    Donut Jun 11, 2019
    citrus13 likes this.
  14. koocha
    Gingerbread Jun 11, 2019
  15. MattBoxer
    MattBoxer , Jun 11, 2019 :
    Glad to know that I'm not the only one with that issue, I talked to support twice today and the 1st told me to reinstall 9.5.7 which didn't work and I got back to them and didn't end up with any result after that . I'll wait for their response to my follow up email but my (fingers crossed) guess is hopefully it'll be fixed by the next update.
  16. koocha
    Gingerbread Jun 12, 2019
    koocha , Jun 12, 2019 :
    my car charger arrives today. This issue will take the shine off it [e]1f614[/e]
    MattBoxer likes this.
  17. Menahjatwa
    Eclair Jun 12, 2019
    Menahjatwa , Jun 12, 2019 :
    My Warp Charge works but i have exactly the same problem as Koocha when i use my Dash Charge, it charges the phone but the lightning symbol appears for like a second then it goes to regular charging.
    Do you think factory resetting the phone may fix this problem or the phone is faulty?
  18. MattBoxer
    MattBoxer , Jun 12, 2019 :
    Factory resetting didn't work for me and I wouldn't say it's a hardware problem with the phone, it depends whether you only saw it after the 9.5.7 update or not.
    I don't think the charger is faulty after not having it for that long tbh as it seems for me warp and dash charging seems limited at max at 1-1.2 amps before the software triggers something (I think firmware) and makes the charging stop and start.
    lirannl likes this.
  19. Menahjatwa
    Eclair Jun 12, 2019
    I had the problem since I got the phone out of the box, then I updated the phone via Oxygen Updater to 9.5.7 which result to same issue.
    My OP7P is the Chinese variant GM1910.
  20. dennnath22
    Donut Jun 12, 2019
    dennnath22 , Jun 12, 2019 :
    Even I have stopped getting the notification of warp charging upon connecting the charger since the recent update? Is that normal?
    Erisker, Menahjatwa and MattBoxer like this.
