20
Oneplus 7pro warp charge not working
  1. L1560352039307
    Cupcake Jul 9, 2019
    L1560352039307 , Jul 9, 2019 :
    Hi guys so my girlfriend's plus 7 pro was doing the whole not charging thing. I have a warp charger for my 7 pro as well but we were miles away from each other so she couldn't try mine. Anyways we sent it off and it came back today turns out it's just the charger. Well the repair report said software update was the repair but I think that's a lie cus it's the same as everyone's .8. I think you guys should try a new charger and see if that works cus I swear that had to be the reason.
  2. Menahjatwa
    Eclair Jul 10, 2019
  3. insomnia77
    Froyo Jul 10, 2019
    insomnia77 , Jul 10, 2019 :
    I take it back. Since 9.5.9 it doesnt seem to charge as quick. For example it took 1.5 hours to charge from 23% to 100% . I have the charger plugged into a plug splitter so I need to test without out it. I'm also wondering if it's a glitch that a factory reset could fix
    Update ran somemore tests without plug splitter . It charges 0-100% IN 1.5 HOURS. not as quick as some YouTube reviews showing one hour but I guess this is in line with others showing 1.5
  4. koocha
    Gingerbread Jul 11, 2019
    koocha , Jul 11, 2019 :
    I'll have a go tonight. got a plug and a car charger, both Dash
  5. jaynish1116
    Cupcake Jul 14, 2019
    jaynish1116 , Jul 14, 2019 :
    In My OnePlus 7 pro warp charging is not working after new update. It charging normally .plzz help me fix it
  6. sschaky
    Cupcake Jul 15, 2019
    sschaky , Jul 15, 2019 :
    Nobody can help you mate. OnePlus didn't even issued a statement or confirm the problem.
    It is unacceptable to fully charge a phone for 5 hours nowadays. Think I'm gonna send it back now after waiting 4 weeks for a fix...
  7. Menahjatwa
    Eclair Jul 15, 2019
    Menahjatwa , Jul 15, 2019 :
    How did it go with the Dash Adapter, any luck?
  8. koocha
    Gingerbread Jul 15, 2019
    koocha , Jul 15, 2019 :
    didn't get to try it. I'll have a go later on in the week
  9. Menahjatwa
    Eclair Jul 15, 2019
    How long does it take to fully charge the phone now?
  10. Swejuggalo
    Lollipop Jul 15, 2019
    Swejuggalo , Jul 15, 2019 :
    If you haven't rooted the phone and played with magisk modules and possible other stuff that could break stuff in the OS it's a pretty high risk that something is broken in the hardware. It's either your phone, your cable or your charger.
    If it's still broken after a factory reset, and different charger and cable I would be very surprised if it would be a software bug with only some units here and there in the world.
  11. koocha
    Gingerbread Jul 18, 2019
  12. koocha
    koocha , Jul 18, 2019 :
    not sure - a long time. I drive around a lot and have it plugged into my car for Android Auto so it never gets really low
  13. Menahjatwa
    Eclair Jul 18, 2019
    Menahjatwa , Jul 18, 2019 :
    Wait, what I am still on 9.5.8 how are you getting 9.5.10?
  14. koocha
    had 9.5.9 in-between that too.
    Oxygen updater in Google Play
  15. Menahjatwa
    Eclair Jul 18, 2019
    Oh,I've been waiting for the update notification to pop up on my phone and it hasn't appeared.
  16. koocha
    don't bother waiting. Oxygen Updater will download it for you and you can use the local upgrade option to install it
  17. iOStoAndroid
    iOStoAndroid , Jul 18, 2019 :
    Same issue.. Mine was capping at 3amps with 9.5.9 update. I got the 9.5.10 now and it's capped at 1.3amps... It worsened with 9.5.10.. Wtf??
    Edit: symptom is the same. Under 3amp charge.. It says warp charging.. But only get up to 3amp.. This is when around 40% battery..
  18. koocha
    oh geez...I'll let mine flatten a bit and try warp charging later
  19. iOStoAndroid
    Gingerbread Jul 22, 2019
  20. koocha
    koocha , Jul 22, 2019 :
    I've been told it'll be fixed in a software update
