20
Oneplus 7pro warp charge not working
  1. khanna307
    Cupcake Nov 22, 2019
    khanna307 , Nov 22, 2019 :
    I had the same issue for 4 days after updating, tried everything but nothing worked... Surprisingly what worked was.. just remove the USB connector from the Warp charge block and reconnect it back
    Worked for me! Warp charging now ..
  2. W1577640509233
    Cupcake Dec 29, 2019
    W1577640509233 , Dec 29, 2019 :
    My one plus 7T has the problem. Did you figure it out?
  3. Hargovind.2.3
    Cupcake Jan 9, 2020
    Hargovind.2.3 , Jan 9, 2020 :
    I'm facing the same issue on my 7t, can you please send me log and video
  4. shrikanthsy
    Cupcake Jan 11, 2020
    shrikanthsy , Jan 11, 2020 :
    Hey guys, so I am having the same issue since today morning. Read through all the pages and different forums. Looks like no one has found a solution yet or it's most likely a hardware issue. I think even a small particle of dust could cause the warp charger to stop working. Mine was working fine until last night. It's a shame the hardware isn't protected enough against small dust and other stuff. I am on Pie beta version. Tried cleaning the charging port but no luck. My phone is just one week old. I think I will have to take it to the service centre. Will keep you guys posted on this.
    EDIT: So I cleaned the charging port and blew air. Also wiped the port with a cloth. Switched off the phone for 10 minutes. And the warp charging started working once I switched it back on. If you are not rooted then it's definitely a hardware issue. Try cleaning the port carefully once with whatever tools you have. But make sure not to further scratch it or damage it.
  5. Q1579195628618
    Cupcake Jan 16, 2020
    Q1579195628618 , Jan 16, 2020 :
    In my case, It was the USB charge cable. Swapped it with a new one and it started warp charging again. If this one stops warp charging too, I'll have to find some high quality cables.
  6. L1576231699803
    L1576231699803 , Jan 16, 2020 :
    It is taking nearly 1hr-30min to charge 1%_100% charging..I don't think it's wrap charging.. now how can i get rid of this issue..kindly help me..
    please clear my issue...
  7. herach
    Eclair Mar 2, 2020
    herach , Mar 2, 2020 :
    Hello all. I'm in US. I purchased mine from US T-Mobile. I'm having the same problem. After the F/W update the home Warp charger is not Warp charging anymore but the Car Warp charger is working fine. I hope Oneplus fixes this problem quick.
