20
Oneplus 7pro warp charge not working
  1. MattBoxer
    Gingerbread Jun 18, 2019
    #81
    koocha likes this.
  2. MattBoxer
    MattBoxer , Jun 18, 2019 :
    Even the full update didn't fix it for me :/
    #82
  3. koocha
    #83
    MattBoxer likes this.
  4. MattBoxer
    Don't know whether to be happy or sad about this ;), I do think the bug hunter would get back to me first if they had found anything. :)
    #84
  5. koocha
    koocha , Jun 18, 2019 :
    it makes me sad that I've mentioned it to OnePlus on at least 5 separate occasions and I've had no reply from them at all
    #85
  6. Menahjatwa
    Eclair Jun 19, 2019
    #86
  7. MattBoxer
    Gingerbread Jun 19, 2019
    MattBoxer , Jun 19, 2019 :
    That's a strange one as your dash charge acts exactly like warp charge for me (and dash charge acts the same as that)but my issue adds the stage of no charging as well which makes it far worse as the phone charges unbelievably slowly at that point.
    #87
  8. Menahjatwa
    Eclair Jun 19, 2019
    Menahjatwa , Jun 19, 2019 :
    Only way to tell is to get your hand on another Warp Powerbrick and run your test with that I suppose, if that still causes same issue than you might have a defect unit. I really hope this will get fixed once they release Android Q or something.
    #88
  9. C1541308074807
    Donut Jun 19, 2019
    C1541308074807 , Jun 19, 2019 :
    please somebody help me through this.. my warp charge is really not upto the mark. it takes about 1hour and 30 minutes to charge fully .. and about 47% in 30 minutes., this is the results I got after doing the test for 5 times and in a room with air conditioner,, and also by switching off the phone
    #89
  10. MattBoxer
    Gingerbread Jun 20, 2019
    MattBoxer , Jun 20, 2019 :
    Update to anyone who has had this issue, I finally got a response from a bug hunter and unfortunately they say it's a hardware issue.. Let's hold up for a second. :3
    Legit just got another email back saying it's a software issue now looks like it has to do with otg maybe. This is some good evidence now to say it's definitely software!!
    #90
  11. MattBoxer
    MattBoxer
    Well, it's now a hardware issue again :-\
    Edit: @koocha not good news for us. ಠ_ಠ
    #91
    Narayan_Shrestha likes this.
  12. Menahjatwa
    Eclair Jun 20, 2019
    Menahjatwa , Jun 20, 2019 :
    So basically we all got the doomed 1st batch of OnePlus 7 Pro, just like when X-Box 360 came out when everybody got the "Red Ring of Death."
    #92
  13. MattBoxer
    He also said that the most affected devices were in India cause by high temps but me an a few others were from the UK so I don't know how it would've happened. =_=
    #93
  14. Menahjatwa
    Eclair Jun 20, 2019
    I'm gonna wait til Warp Charge adapter is readily available in my country (Indonesia) that's the only way I can know for sure if it's the brick thats faulty or the phone itself.
    #94
  15. Narayan_Shrestha
    Froyo Jun 20, 2019
    Narayan_Shrestha , Jun 20, 2019 :
    So by hardware they mean its a faulty power brick and cable or something wrong in the phone internals?
    I get a charging speed of around 5800mA for a few minutes when I charge initially and then it falls down and averages around 3500 mA. Is this the correct speed warp charge should deliver?
    #95
  16. MattBoxer
    That sounds totally normal, the peak is 5amps then it will settle around 3amps, mine peaks at 5 for a few seconds goes to 1 amp then switches between warp, normal and no charging at all, and I'm pretty sure he means phone internals, as I think another person on here has two warp chargers and a car warp charger and the issue still exists.
    #96
  17. C1541308074807
    Donut Jun 20, 2019
    C1541308074807 , Jun 20, 2019 :
    my phone stays above 5amps for just a few seconds and goes back to 3.4 amps( aprox).. is this normal??
    #97
  18. MattBoxer
    Yes that seems normal.
    #98
  19. C1541308074807
    Donut Jun 20, 2019
    but I can't really tell the diference between the dash charger and the warp.. both charges the phone identically..
    #99
  20. MattBoxer
    Update guys, I have submitted for a replacement device that the support team immediately put through as soon as I showed them the emails that the bug hunter sent to me. It'll take 3-6 days and I've asked a friend to borrow their old phone for now. When I get the new phone, I'll test it before any updates, then update it to the latest version to see if it is once an for all a software issue!
    C1541308074807 likes this.
