Working OnePlus 7t battery draining
  1. C1571917708599
    Cupcake Nov 10, 2019
    kãräñ_90564 likes this.
  2. azeemnalka
    Cupcake Nov 12, 2019
    azeemnalka , Nov 12, 2019 :
    new WhatsApp update has hit many Brand New Android phones and OnePlus got it worst try uninstalling WhatsApp and use it for couple of days if it still the same then go for replacement
  3. Gav_W86
    Starting Point Expert Nov 12, 2019
    Gav_W86 , Nov 12, 2019 :
    what do the battery use screens in settings say is using your battery?
  4. P12OTOTYP3
    Cupcake Nov 13, 2019
    P12OTOTYP3 , Nov 13, 2019 :
    My battery life seem to last me. I have WhatsApp installed but it doesn't drain much of the battery.
  5. Gav_W86
    Starting Point Expert Nov 13, 2019
  6. P1575130125627
    Cupcake Dec 4, 2019
    P1575130125627 , Dec 4, 2019 :
    Hi Team,
    Please Help.
    I purchased this phone on 30th Nov from amazon. but I found battery drianing at very fast rate.
    earlier I installed number of application.but I tested it by even after factory reset and using only YouTube..I am not comfortable with the battery performance.
    even i haven't use any sim.so battery performance is far below the expectation.
    please refer the screenshot of battery using YouTube over WiFi (post factory reset).
    also I am requesting you to please suggest how can in replacement this with good phone (as I purchased it under 10 day replacement from amazon.in)
    please help.
  7. Matty1134
    Cupcake Dec 5, 2019
  8. Anothen
    Cupcake Dec 10, 2019
    Anothen , Dec 10, 2019 :
    this seems to be the norm for me. Second full day of usage and it is not living up to what I was hoping.
  9. Gav_W86
    Starting Point Expert Dec 11, 2019
    Gav_W86 , Dec 11, 2019 :
    what apps/services are using the battery (click on the view detailed use button)
    Anothen likes this.
  10. Anothen
    Cupcake Dec 11, 2019
  11. Anothen
    Anothen , Dec 11, 2019 :
    see screenshots. debating on wiping and starting over or requesting a replacement
  12. Anothen
    Cupcake Dec 12, 2019
  13. L1570370241006
    Cupcake Dec 16, 2019
  14. Gav_W86
    Starting Point Expert Dec 16, 2019
    Gav_W86 , Dec 16, 2019 :
    def worth trying a backup/factory reset
  15. Gav_W86
