Oneplus 7t battery replacement via OnePlus 7T Glacier Blue
  1. #1
  2. camohan
    Moderator Moderator Sep 20, 2021
    camohan , Sep 20, 2021 :
    Hi there, if you carry out any hardware repairs, rectifications through OnePIus, it will not void the warranty.
    However, if you plan to do it on your own or through a third party repair services it will void the warranty for obvious reasons.
    Usually it's the battery that takes a toll, so replacing it might be a good idea and it will give the phone a new life, in case you plan to use the existing phone longer.
    Cheers.
  3. BeingIncog
    Nougat Sep 20, 2021
    BeingIncog , Sep 20, 2021 :
    water resistance not warranty...
    like what i have here after my display repair in Jan, back panel lifting after 2-3 months : upload_2021-9-20_23-36-1.png
  4. camohan
    BeingIncog likes this.
