2
OnePlus 7T does not intelligently select best Wi-Fi via OnePlus 7T
  1. C1570026132556
    Cupcake Dec 30, 2020
    C1570026132556 , via OnePlus 7T , Dec 30, 2020 :
    OnePlus 7T does not intelligently select best Wi-Fi. It takes about more than 10-15 mins for 7T to switch to strong signal Wi-Fi. I have to manually select strong signal Wi-Fi.
    B1612535766977 and Lemillion like this.
  2. ghostofcain
    Marshmallow Dec 30, 2020
    ghostofcain , Dec 30, 2020 :
    I'm no expert, but I suspect the phone sticks to the existing network until it impinges upon perfomance, otherwise you'd be continually hopping networks and the battery drain would be horrific.
  3. C1570026132556
    Cupcake Dec 31, 2020
    C1570026132556 , via OnePlus 7T , Dec 31, 2020 :
    I get your point but phone sticks to current network even when it shows low signal with ! no internet symbol.
  4. #4
    SRD. likes this.
  5. Karx100
    Gingerbread Dec 31, 2020
  6. SoorajMurtadak
  7. SRD.
    Lollipop Dec 31, 2020
  8. dom_k
    The Lab - OnePlus 9 Pro Reviewer Dec 31, 2020
  9. #9
  10. MohanParmar
  11. MohanParmar
    MohanParmar , via OnePlus 7T Glacier Blue , Dec 31, 2020 :
    Yes, you may use WIFI preferences settings to automatically turn on wifi when you are at home.
    GPS must be enabled all the time.
    Not sure about automatic turn off.
  12. #12
  13. MRTLima
    MRTLima , via OnePlus 7T , Dec 31, 2020 :
    Very good suggestion from our friend.
