OnePlus 7T fingerprint problem after display change via OnePlus 7T
  1. Nitin_ranjan_10
    Cupcake Sep 30, 2020
    Nitin_ranjan_10 , via OnePlus 7T , Sep 30, 2020 :
    My fingerprint is not working properly.sometimes it doesn't even unlocks after 5 tries and sometimes it opens at one go but mainly i have to scan it multiple times for unlocking apps.
  2. NumberSix
    Honeycomb Sep 30, 2020
    NumberSix , Sep 30, 2020 :
    Mine does that but with only one thumb weirdly and no matter how many times i clear it and put the print in again it is just the same.
  3. Swatiranjan
    KitKat Oct 1, 2020
    Swatiranjan , via OnePlus 7T , Oct 1, 2020 :
    Hello, are you using a tempered glass or any screen protection ??? If yes, please check if it's installed properly.
    If you have changed your display and no screen protector is there, plz check the service centre they should check it without any cost implementation.
  4. Rajendra.Bhat
    Ice Cream Sandwich Oct 1, 2020
  5. Nitin_ranjan_10
    Cupcake Oct 1, 2020
