2
oneplus 7t OP7T double tap wake up not working
  1. Jasdeep Singh Jolly
    Cupcake Oct 11, 2019
    C1516324465305 and devendrakadam like this.
  2. T1570814621246
  3. #3
  4. #4
  5. Q1569546942030
    Cupcake Oct 13, 2019
  6. O1571042518872
    Cupcake Oct 14, 2019
    O1571042518872 , Oct 14, 2019 :
    either you enable "tap the screen to show" in ambient display or you enable double tap to wake. you cannot make both work together, maybe thats why its not working for you.
  7. F_Srinivasa_Madaiah_kXAd , via OnePlus 7T , Oct 16, 2019 :
    Tap the screen is in off position. But still double tap to wake up is not working.
  8. N1571235840411
    Cupcake Oct 16, 2019
  9. N1570025511807
    Cupcake Oct 18, 2019
  10. pratikstrange
  11. Rj_parihar
    Rj_parihar , Oct 18, 2019 :
    Me also facing same issue.. the whole ambient thing is not working. Annoyed by it now as it doesn't have notification light either
  12. Akashkhairajani
    Cupcake Oct 21, 2019
    Akashkhairajani , Oct 21, 2019 :
    Same. Please fix the issue with an update.
    Also when night mode is on and you unlock your phone there's a transition happening everytime from regular to night mode, anyone else facing this?
    Julski11 likes this.
  13. TomsonThomas24
    Eclair Oct 21, 2019
  14. TomsonThomas24
    Eclair Oct 21, 2019
  15. TomsonThomas24
    Eclair Oct 21, 2019
  16. TomsonThomas24
    Eclair Oct 21, 2019
    TomsonThomas24 , Oct 21, 2019 :
    I am also having the same issue. Can anybody suggest what to do. Is the problem solved . Is it becoz of the software or hardware issue. Please help
  17. F1571812237878
    Cupcake Oct 23, 2019
  18. danny jraige
    Eclair Oct 24, 2019
    danny jraige , Oct 24, 2019 :
    is there still no fix for this I am aware you cannot have double tap and tap to show enabled at same time. when you enable one other is automatically disabled but I have double tape to show and only works first time than stops working
  19. jedna_ljubav
    Cupcake Oct 26, 2019
    jedna_ljubav , Oct 26, 2019 :
    Double tap to wake works for me for the first 20-30 minutes then it stops working for some reason. To make it work again I have to unlock the phone with the power button, then only DT to wake starts working again for some time.
  20. Kingwolfen
    Cupcake Oct 27, 2019
